[mpich-discuss] Facing problem while using MPI_File_set_view
    Christina Patrick
    christina.subscribes at gmail.com
    Sat May 30 21:19:40 CDT 2009
Thank you very much for giving me the fix. I really appreciate it.
I will try it out and let you know.
Christina.
On Sat, May 30, 2009 at 3:03 AM, Wei-keng Liao
<wkliao at ece.northwestern.edu> wrote:
> Hi, Christina,
> There is another bug at line 970 in the same file.
> The problem has been pointed out by the comments above that line.
> A quick fix is: (starting from line 958)
> +    if (file_ptr_type == ADIO_INDIVIDUAL)
> +        fd->fp_ind =
> file_offsets[file_list_count-1]+file_lengths[file_list_count-1];
>    ADIOI_Free(file_offsets);
>    ADIOI_Free(file_lengths);
> -    /* Other ADIO routines will convert absolute bytes into counts of
> datatypes */
> -    /* when incrementing fp_ind, need to also take into account the file
> type:
> -     * consider an N-element 1-d subarray with a lb and ub: (
> |---xxxxx-----|
> -     * if we wrote N elements, offset needs to point at beginning of type,
> not
> -     * at empty region at offset N+1) */
> -    if (file_ptr_type == ADIO_INDIVIDUAL) {
> -        /* this is closer, but still incorrect for the cases where a small
> -         * amount of a file type is "leftover" after a write */
> -        fd->fp_ind = disp + flat_file->indices[j] +
> -            ((ADIO_Offset)n_filetypes)*filetype_extent;
> So, together with the earlier fix at line 477, I can run your test code
> even with MPI_Type_create_subarray() and #define COLL_BUFSIZE (8388608)
> Wei-keng
> On May 29, 2009, at 11:38 PM, Wei-keng Liao wrote:
>> Hi, Christina,
>> Can you try the following temporary fix? I believe there is a bug
>> in adio/ad_pvfs2/ad_pvfs2_read.c, line 477. Please replace
>>               file_lengths[0] = st_frd_size;
>> with
>>               file_lengths[0] = ADIOI_MIN(st_frd_size, bufsize);
>> I tested you program with this fix and it ran fine.
>> (I used mpich2-1.0.8p1)
>> Wei-keng
>> On May 28, 2009, at 1:28 PM, Christina Patrick wrote:
>>> Yeah sure. Please go ahead.
>>> In case you'll are able to figure out where the problem lies, please
>>> do let me know so that I can download the patch.
>>> Also, could you please tell me how to download the CVS version? And,
>>> is the problem going away with the latest mpich CVS or pvfs CVS
>>> versions?
>>> Thanks and Regards,
>>> Christina.
>>> On Thu, May 28, 2009 at 8:43 AM, Rob Latham <robl at mcs.anl.gov> wrote:
>>>> On Wed, May 27, 2009 at 06:04:28PM -0400, Christina Patrick wrote:
>>>>> Thank you very much. Since the API MPI_Type_create_subarray() is very
>>>>> easy to use as compared to other API's used to create data types in
>>>>> MPI, I would really appreciate a solution to this problem.
>>>>> FYI: I am using pvfs 2.8.0.
>>>>> I will check it out with pvfs2.8.1 and keep you posted.
>>>> I think 2.8.1 will also crash.  You will probably have to download the
>>>> CVS version if you want things to work right now.  We can work on
>>>> figuring out just what changed between 2.8.1 and recent CVS.
>>>> Can we add your program to the PVFS testsuite?
>>>> ==rob
>>>> Rob Latham
>>>> Mathematics and Computer Science Division
>>>> Argonne National Lab, IL USA
