[mpich-discuss] Facing problem while using MPI_File_set_view
    Christina Patrick
    christina.subscribes at gmail.com
    Mon May 25 16:19:42 CDT 2009
Hi Everybody,
I am writing a program to read an array of 16384 x 16384 of type
double ~ 2GB file size
I am using the file view as follows:
|                             |    P0
|                             |    P1
|                             |    P2
|                             |    P3
I create the file view using MPI_Type_create_subarray() and use
collective I/O MPI_File_read_all()
When I read the entire file view of P0 (P1, P2, P3) into a buffer
(512MB) (in a single instance), the program works fine.
However, I do not want to use a buffer as big as 512 MB. So I use a
smaller buffer (such as 8MB) and iterate over the file view of P0 (P1,
P2, P3), my program starts throwing errors/get segmentation faults:
[E 16:49:28.377861] Error: payload_progress: Bad address
OR
segmentation fault in ADIOI_Calc_my_off_len() at line: while
(flat_file->type != fd->filetype) flat_file = flat_file->next;
because flat_file becomes 0x0 in one of the processes.
If I use a column view and logically do the same thing, I do not face
this problem. (I hope that I have been able to explain the problem. In
case of doubt, please let me know.)
Could somebody please help me,
Thanks and Regards,
Christina.
PS: I am pasting the program below:
#include "mpi.h"
#include <stdio.h>
#include <string.h>
#include <stdlib.h>
#include <math.h>
#include <errno.h>
#define ROWS                (16384)
#define COLS                (16384)
#define MPI_DATATYPE        (MPI_DOUBLE)
#define C_DATATYPE          double
#define DIMS                (2)
#define COLL_BUFSIZE        (536870912)
int main(int argc, char **argv) {
  char          fname[] = "pvfs2:/home/mdl/patrick/pvfs2/testfile";
  int           i = 0, nprocs = 0, mynod = 0, provided = 0, c_size =
0, mpi_size = 0, iterations = 0,
                array_size[] = {0, 0}, array_subsize[] = {0, 0},
array_start[] = {0, 0};
  long          rows = 0l, cols = 0l, coll_bufsize = 0l, rows_view =
0l, cols_view = 0l, rows_collbuf = 0l, cols_collbuf = 0l, elts_collbuf
= 0l;
  unsigned long filesize = 0l;
  double        *buffer = NULL;
  MPI_File      fhandle;
  MPI_Status    status;
  MPI_Datatype  subarray;
  MPI_Init_thread(&argc, &argv, MPI_THREAD_MULTIPLE, &provided);
  MPI_Comm_rank(MPI_COMM_WORLD, &mynod);
  MPI_Comm_size(MPI_COMM_WORLD, &nprocs);
  MPI_Type_size(MPI_DATATYPE, &mpi_size);
  c_size     = sizeof(C_DATATYPE);
  if(c_size != mpi_size) {
    fprintf(stderr, "Datatypes in MPI and C do not match\n");
    MPI_Abort(MPI_COMM_WORLD, EIO);
  rows             = ROWS;
  cols             = COLS;
  coll_bufsize     = COLL_BUFSIZE;
  elts_collbuf     = coll_bufsize / mpi_size;
  rows_view        = rows / nprocs;
  cols_view        = cols;
  cols_collbuf     = cols_view;
  rows_collbuf     = elts_collbuf / cols_collbuf;
  filesize         = rows * cols * mpi_size;
  array_size[0]    = rows;
  array_size[1]    = cols;
  array_subsize[0] = rows_view;
  array_subsize[1] = cols_view;
  array_start[0]   = rows_view * mynod;
  array_start[1]   = 0;
  buffer = (C_DATATYPE *)malloc(coll_bufsize);
  if(!buffer) {
    fprintf(stderr, "calloc error\n");
    MPI_Abort(MPI_COMM_WORLD, ENOMEM);
  MPI_File_open(MPI_COMM_WORLD, fname, MPI_MODE_RDONLY, MPI_INFO_NULL,
&fhandle);
  MPI_Type_create_subarray(DIMS, array_size, array_subsize,
array_start, MPI_ORDER_C, MPI_DATATYPE, &subarray);
  MPI_Type_commit(&subarray);
  MPI_File_set_view(fhandle, 0, MPI_DATATYPE, subarray, "native",
MPI_INFO_NULL);
  iterations = rows_view / rows_collbuf;
  for(i = 0; i < iterations; i++)
    MPI_File_read_all(fhandle, buffer, elts_collbuf, MPI_DATATYPE, &status);
  MPI_File_close(&fhandle);
  free(buffer);
  MPI_Finalize();
  return 0;
