[mpich-discuss] How to send SIGINT to each process
abhishek pandey
hipandey at gmail.com
Wed May 13 14:07:16 CDT 2009
Thanks for quick response.
Forgot to mention last time, I need to pass SIGINT to each process on
window/vista
I am launching the job with
mpiexec.exe -configfile <configfile>.
and on each client, smpd.exe is installed.
Abhishek
On Thu, May 14, 2009 at 12:26 AM, Darius Buntinas <buntinas at mcs.anl.gov>wrote:
> If you're using mpd as the job launcher, you should be able to use
> mpdsigjob.
> -d
> On 05/13/2009 01:54 PM, abhishek pandey wrote:
> > Hi,
> > Is there anyway to pass SIGINT signal to each process from mpiexe ?
> > The problem is whenever I press ctrl+C, mpiexe kills all the processes
> > and I am not able to customize the exit of my program.
> > I tried to find out the answer on net but dint get anything.
> > Thanks,
> > Abhishek
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20090514/43786045/attachment.htm>
