[mpich-discuss] Cannot build mpich2-1.0.8p1 (nemesis) with PGI	8.0-4 on Linux x86_64
    Dave Goodell
    goodell at mcs.anl.gov
    Tue Mar 31 12:53:28 CDT 2009
On Mar 31, 2009, at 10:54 AM, Gus Correa wrote:
> Dave: Thank you very much for the configure.in
> patch and for your help.
> I applied the patch, did "make distclean", deleted all old
> build files and directories, configured again, did make again.
> However, I still get the same exact error on the make phase.
> There may be more that needs to be patched in configure.in, I'd guess.
Hi Gus,
I forgot to tell you to run "./maint/updatefiles" in order to
regenerate the configure from the configure.in.  You'll need perl and
autoconf-2.62 or later to go that route though.  Sorry about the mix-up.
If you prefer, you can use the tarball I've created here [1] that
already has the patch and has an already-regenerated configure script.
-Dave
[1] http://www.mcs.anl.gov/~goodell/mpich2-1.0.8p1-pgcc.tar.gz
