[mpich-discuss] Hang inside MPI_Waitall with x86_64
    Saurabh Tendulkar
    gillette206 at yahoo.com
    Mon Mar 30 15:13:32 CDT 2009
I have some code that often (but not always) hangs at very similar locations inside MPI_Waitall. This happens *only* on 64-bit linux (x86_64, redhat el5, gcc 4.1) and as far as I can tell only with optimized code (-O2 for the app; mpich itself was built with default settings). I've tried MPICH 1.2.3 and the latest 1.2.7p1.
This is a 3-process run. The stack traces of the 3 processes (A, B, C) are as follows (these are rank independent - even with the same mpirun settings).
A:
#0  __select_nocancel () from /lib64/libc.so.6
#1  net_recv ()
#2  socket_recv_on_fd ()
#3  socket_recv ()
#4  net_send_w ()
#5  net_send ()
#6  net_send2 ()
#7  socket_send ()
#8  send_message ()
#9  MPID_CH_Rndvb_ack ()
#10 MPID_CH_Check_incoming ()
#11 MPID_DeviceCheck ()
#12 MPID_WaitForCompleteSend ()
#13 MPID_SendComplete ()
#14 PMPI_Waitall ()
B:
#1  p4_sockets_ready ()
#2  net_send_w ()
#3  net_send ()
#4  net_send2 ()
#5  socket_send ()
#6  send_message ()
#7  MPID_CH_Rndvb_ack ()
#8  MPID_CH_Check_incoming ()
#9  MPID_DeviceCheck ()
#10 MPID_WaitForCompleteSend ()
#11 MPID_SendComplete ()
#12 PMPI_Waitall ()
Note: #0 could instead be recv ()
C:
#0  __write_nocancel () from /lib64/libpthread.so.0
#1  net_send_w ()
#2  net_send ()
#3  net_send2 ()
#4  socket_send ()
#5  send_message ()
#6  MPID_CH_Rndvb_ack ()
#7  MPID_CH_Check_incoming ()
#8  MPID_DeviceCheck ()
#9  MPID_WaitForCompleteSend ()
#10 MPID_SendComplete ()
#11 PMPI_Waitall ()
Note: Instead of #0-#5 for C, there can be: (#6-#11 are the same as #4-#9 here)
#1  socket_recv ()
#2  recv_message ()
#3  p4_recv ()
The MPI_Waitall is after an MPI_Irecv/MPI_Isend block exchanging data between the three processes. I have verified all counts of data etc. Note that this shows up only with 64-bit linux. It does not always happen, but when it does, it's with the stack traces as above.
I am not at all familiar with MPICH internals, so I do not know what is going on here. Can anyone shed some light, and suggest what to look for in my code that might be causing these problems?
Thank you.
saurabh
