[mpich-discuss] MPICH on Single Machine (vivian)
Vivian
viviantj at gmail.com
Thu Mar 26 13:26:16 CDT 2009
Hi, Andy,
(1) If all the processors are in one computer, you don't need to
identify host names.
"mpiexec –n 16 c:\program files\mpich2\examples\cpi.exe"
(2) If the processors distribute in different computers connected
through a network, you need to find the following information for each
computer.
Domain Name: domainname (It is required to find a
computer in the network)
Host Name: hostname (The host name can be used to
identify a computer only when all the computers are in the same subnetwork.)
IP Address: 1.2.3.4
User Name: username (The user name required to log
in the machine)
Password: ********** (The corresponding password
required to log in the machine)
Then you need to register each “user” in the master node so that a
domain name, user name and password can be automatically retrieved by
mpiexec to launch processes.
"mpiexec –register user 1 domainname\username\**********"
After the above steps, you can run
"mpiexe c –hosts 16 domainnameA 1 domainnameB 1 ..... c:\program
Vivian
> Message: 1
> Date: Wed, 25 Mar 2009 15:55:45 -0400
> From: "Robertson, Andrew" <andrew.robertson at atk.com>
> Subject: [mpich-discuss] MPICH on Single Machine
> To: <mpich-discuss at mcs.anl.gov>
> Message-ID:
> <25F430F61D9E9A459832065C99EA390B03BD4D36 at ny10se01.atk.com>
> Content-Type: text/plain; charset="us-ascii"
> Folks
> I have a program that does not have any shared memory parallelization.
> Thus even though the 16 processors of my quad socket / quad core machine
> are on the same motherboard, I need to have mpich2 up and running.
> I need to get the machine a name so it isnt localhost
> I start an mpd with no host name or node count
> I fire up the job with an mpiexec -n 16
> Or am I missing something here? Do I need an mpdboot that fires up 16
> daemons?
> Should I be using gforker?? If so how is that done?
> Thanks
> - Andy
> Andrew Robertson P.E.
> CFD Analyst
> GASL Operations
> Tactical Propulsion and Controls
> ATK
> 77 Raynor Avenue
> Ronkokoma NY 11779
> 631-737-6100 Ext 120
> Fax: 631-588-7023
> www.atk.com
> !! Knowledge and Thoroughness Baby !!
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20090326/69cdb167/attachment.htm>
