[mpich-discuss] mpich2 MPI_TEST errors
    Pavan Balaji
    balaji at mcs.anl.gov
    Sun Mar 15 16:19:42 CDT 2009
> I found the Culprit function
> it was indeed a problem with mpi_test call , i tracked it down, the programs works now.
Great!
> But now i am having a hard time using the same program to run on mpich2 1.0.8/PBS on a x86_64 system.
> it compiles and runs perfectly as a single process,
> ie, mpiexec -n 1 ./Ring
> executes and generates outputs.
> but as soon as i do mpiexec -n 2 or more , it just waits and eventually the job is thrown out of the queue.
Did you launch your mpd daemons correctly? See section 5.7.1 in the
MPICH2 users' guide:
http://www.mcs.anl.gov/research/projects/mpich2/documentation/files/mpich2-1.0.8-userguide.pdf
PBS uses a slightly different node name representation that MPICH2's
MPD, but it should be trivial to convert between the two formats.
> Does mpich2 has any special configurations with multiple core machines?
> Any tips on job submission or compiling,
> if just used
> ./configure --with-device=ch3:nemesis
It'll automatically detect multi-core systems and optimize inter-core
communication.
  -- Pavan
Pavan Balaji
http://www.mcs.anl.gov/~balaji
