[mpich-discuss] mpich2 MPI_TEST errors
    Samir Khanal
    skhanal at bgsu.edu
    Sun Mar 15 12:55:52 CDT 2009
Hi Pavan
Thanks for the quick response and am glad that it reached the right person for a response.
i downloaded mpich2 1.0.8 version from the official website.
I am compiling a time-warp library with mpich2 ch3:nemesis channel.
I can run simple programs (like cpi etc), but the problem comes when i try to use the program for this library, (which works perfectly with mpich 1.2.7) it gives a mpi_test failure info.
If you would like to compile the library and test, i can send you the whole package about 1MB in your mcs email.
I am really stuck with this.
Samir
From: mpich-discuss-bounces at mcs.anl.gov [mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Pavan Balaji [balaji at mcs.anl.gov]
Sent: Sunday, March 15, 2009 1:47 PM
Subject: Re: [mpich-discuss] mpich2 MPI_TEST errors
Samir,
Can you send the test program? If all channels are failing, it is very
likely either a problem with the test program or your configuration.
Btw, which version of MPICH2 are you using?
Regarding the new cluster, all you need to use it ch3:nemesis. In a lot
of ways, nemesis is a superset of sock, ssm and shm. The few features
that it is missing (which you'll only notice in special circumstances)
are being added in the 1.1 release of MPICH2.
  -- Pavan
Samir Khanal wrote:
> Hi all
> I was trying to get a library compiled using mpich2,
> it works ok - compiles and executes with mpich 1.2.7 ch3_p4 channel and 1.2.5 but i have problem running it with mpich2.
> Isn't mpich2 backward compatible with mpich 1.2.7 ? I assume that there should not be specific rewrites to work with mpich2...
> I compiled mpich2  with
> --with-device=ch3:nemesis
> and all other 3 options
> sock
> ssm
> shm
> what should be the channel to be compatible with ch3_p4 as in mpich-1.2.7
> The error i receive is
> mpiexec -n 1 ./test
> Fatal error in MPI_Test: Invalid MPI_Request, error stack:
> MPI_Test(152): MPI_Test(request=0x869e1dc, flag=0xbfa134f8, status=0xbfa134d0) failed
> MPI_Test(75).: Invalid MPI_Requestrank 0 in job 19  protos.cs.bgsu.edu_46623   caused collective abort of all ranks
>   exit status of rank 0: killed by signal 9
> mpiexec -n 2 ./test
> MPI_Test(152): MPI_Test(request=0x92451dc, flag=0xbf8c4938, status=0xbf8c4910) failed
> MPI_Test(152): MPI_Test(request=0x8bdc1dc, flag=0xbfb77be8, status=0xbfb77bc0) failed
> MPI_Test(75).: Invalid MPI_Requestrank 0 in job 20  protos.cs.bgsu.edu_46623   caused collective abort of all ranks
> i am using correct mpicxx and mpicc and mpi.h versions in includes
> infact i use
> include "mpi.h" so that appropriate version header gets pulled in automatically
> I also have another question
> I want to compile mpich2 for another cluster with 6 pcs with intel core2quad processors, what appropriate channels should  be used?
> Thanks
> Samir
Pavan Balaji
http://www.mcs.anl.gov/~balaji
