[mpich-discuss] mpich2 MPI_TEST errors
    Samir Khanal
    skhanal at bgsu.edu
    Sun Mar 15 12:39:05 CDT 2009
Hi all
I was trying to get a library compiled using mpich2,
it works ok - compiles and executes with mpich 1.2.7 ch3_p4 channel and 1.2.5 but i have problem running it with mpich2.
Isn't mpich2 backward compatible with mpich 1.2.7 ? I assume that there should not be specific rewrites to work with mpich2...
I compiled mpich2  with
--with-device=ch3:nemesis
and all other 3 options
sock
ssm
shm
what should be the channel to be compatible with ch3_p4 as in mpich-1.2.7
The error i receive is
mpiexec -n 1 ./test
Fatal error in MPI_Test: Invalid MPI_Request, error stack:
MPI_Test(152): MPI_Test(request=0x869e1dc, flag=0xbfa134f8, status=0xbfa134d0) failed
MPI_Test(75).: Invalid MPI_Requestrank 0 in job 19  protos.cs.bgsu.edu_46623   caused collective abort of all ranks
  exit status of rank 0: killed by signal 9
mpiexec -n 2 ./test
MPI_Test(152): MPI_Test(request=0x92451dc, flag=0xbf8c4938, status=0xbf8c4910) failed
MPI_Test(152): MPI_Test(request=0x8bdc1dc, flag=0xbfb77be8, status=0xbfb77bc0) failed
MPI_Test(75).: Invalid MPI_Requestrank 0 in job 20  protos.cs.bgsu.edu_46623   caused collective abort of all ranks
i am using correct mpicxx and mpicc and mpi.h versions in includes
infact i use
include "mpi.h" so that appropriate version header gets pulled in automatically
I also have another question
I want to compile mpich2 for another cluster with 6 pcs with intel core2quad processors, what appropriate channels should  be used?
Thanks
Samir
