[mpich-discuss] HP-XC 3000 cluster issues
    Gauri Kulkarni
    gaurivk at gmail.com
    Wed Mar  4 06:40:43 CST 2009
Ok, I have tried to recompile MPICH2 with following options. I cannot
recompile the 'global version', so I have tried to install it in my home dir
and would update the PATH accordingly. But compiling is failing at the
'configure' step with following error:
command: ./configure --prefix=/data1/visitor/cgaurik/mympi/ --with-pmi=slurm
--with-pm=no
End part of the output:
RUNNING CONFIGURE FOR THE SLURM PMI
checking for make... make
checking whether clock skew breaks make... no
checking whether make supports include... yes
checking whether make allows comments in actions... yes
checking for virtual path format... VPATH
checking whether make sets CFLAGS... yes
checking for gcc... gcc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ANSI C... none needed
checking how to run the C preprocessor... gcc -E
checking for slurm/pmi.h... no
configure: error: could not find slurm/pmi.h.  Configure aborted
configure: error: Configure of src/pmi/slurm failed!
Gauri.
> > > > Message: 4
> > > > Date: Mon, 23 Feb 2009 23:38:06 -0600
> > > > From: "Rajeev Thakur" <thakur at mcs.anl.gov>
> > > > Subject: Re: [mpich-discuss] HP-XC 3000 cluster issues
> > > > To: <mpich-discuss at mcs.anl.gov>
> > > > Message-ID: <72376B2D10EC43F9A0A433C960F951B6 at thakurlaptop>
> > > > Content-Type: text/plain; charset="us-ascii"
> > > > To run MPICH2 with SLURM, configure with the options
> > > > "--with-pmi=slurm
> > > > --with-pm=no" as described in the MPICH2 README file. Also see
> > the
> > > > instructions on how to run MPICH2 with SLURM at
> > > > https://computing.llnl.gov/linux/slurm/quickstart.html .
> > > > Rajeev
> > > >  _____
> > > > From: mpich-discuss-bounces at mcs.anl.gov
> > > > [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Gauri
> > > > Kulkarni
> > > > Sent: Monday, February 23, 2009 11:19 PM
> > > > To: mpich-discuss at mcs.anl.gov
> > > > Subject: [mpich-discuss] HP-XC 3000 cluster issues
> > > > Hi,
> > > > I am a newbie to the MPI in general. Currently in our institute,
> > we
> > > > have a
> > > > cluster of 16nodes-8processors. It is an HP-XC 3000 cluster which
> > > > basically
> > > > means, it's quite proprietary. It has its own MPI implementation
> > > > HP-MPI -
> > > > in which, the parallelization is managed by SLURM (Simple Linux
> > > > Utility for
> > > > Resource Management). There is also a batch job scheduler - LSF
> > (Load
> > > > Sharing Facility) which works in tandem with SLURM to parallelize
> > the
> > > > batch
> > > > jobs. We have installed both MPICH and MPICH2 and are testing it,
> > but
> > > > we are
> > > > running into compatibility issues. For a simple helloworld.c
> > program:
> > > > 1. For HPMPI: Compiled with mpicc of this implemetation and
> > executed
> > > > with
> > > > its mpirun: mpirun -np 4 helloworld works correctly. For batch
> > > > scheduling,
> > > > we need to isse "bsub -n4 [other options] mpirun -srun helloworld"
> > and
> > > > it
> > > > runs fine too. "srun" is SLURM utility that parallelizes the
> > jobs.
> > > > 2. For MPICH and mPICH2: Again, compiled with mpicc of these
> > > > respective
> > > > implemetations and executed with their own mpirun:
> > > >    i) mpirun -np 4 helloword : Works.
> > > >   ii) mpirun -np 15 helloworld: The parallelization is limited to
> > just
> > > > a
> > > > single node - that is 8 processes run first on 8 processors of a
> > > > single node
> > > > and then remaining ones.
> > > >  iii) bsub -n4 [options] mpirun -srun hellowrold: Job terminated.
> > > > srun
> > > > option not recognized.
> > > >   iv) bsub [options] mpirun -np 4 helloworld: Works
> > > >   V) bsub [options] mpirun -np 15 helloworld: (Same as iii)
> > > > Anybody aware of HP cluster issues with MPICH? Am I
> > misinterpreting?
> > > > Any
> > > > help is appreciated.
> > > > Gauri.
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20090304/71cbba20/attachment.htm>
