[mpich-discuss] 32bit and 64bit system issues
    Samir Khanal
    skhanal at bgsu.edu
    Tue Mar  3 17:23:48 CST 2009
And...
When it hangs for a while i do qdel xxx
it spits
compute-0-5.local
Directory is /home/skhanal
This job is running on following Processors
/opt/openmpi/bin/mpiexec
mpiexec: resolve_exe: using absolute path "./lRing".
node  0: name compute-0-5, cpu avail 4
node  1: name compute-0-4, cpu avail 4
node  2: name compute-0-3, cpu avail 4
node  3: name compute-0-2, cpu avail 4
node  4: name compute-0-1, cpu avail 4
node  5: name compute-0-0, cpu avail 4
mpiexec: process_start_event: evt 2 task 0 on compute-0-5.
mpiexec: read_p4_master_port: waiting for port from master.
mpiexec: read_p4_master_port: got port 57476.
mpiexec: process_start_event: evt 4 task 1 on compute-0-4.
mpiexec: process_start_event: evt 5 task 2 on compute-0-3.
mpiexec: process_start_event: evt 6 task 3 on compute-0-2.
mpiexec: All 4 tasks (spawn 0) started.
mpiexec: wait_tasks: waiting for compute-0-5 compute-0-4 and 2 others.
mpiexec: killall: caught signal 15 (Terminated).
mpiexec: kill_tasks: killing all tasks.
p0_14302:  p4_error: interrupt SIGx: 15
bm_list_14303:  p4_error: interrupt SIGx: 15
p0_14302: (1212.847656) net_send: could not write to fd=4, errno = 32
is this Signal 15 caught before or after qdel?
Any hints?
Samir
From: mpich-discuss-bounces at mcs.anl.gov [mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Samir Khanal [skhanal at bgsu.edu]
Sent: Tuesday, March 03, 2009 6:14 PM
Subject: [mpich-discuss] 32bit and 64bit system issues
Hi all
I have a code that has some problems while used in the 64bit system
it runs very well on 32bit system (single core) with mpich-1.2.7 / PBS
but the same thing when compiled for and ran for mpich-1.2.7 / PBS on a 64 bit system just hangs up. (Goes on for a while, This one is a quad core system)
#PBS -n nodes=4:ppn=4
I did
mpiexec -n 4 -pernode ./a.out
to make it look like a single core system. (correct me if i am wrong...)
Both of the 32 and 64 bits systems are rocks clusters 5.1
Is there any drastic change moving from 32 to 64 bit system and from single core to quad core system?
Anything to be careful about?
Thanks
Samir
