[mpich-discuss] build MPICH2-1.1 (shared libs) with IntelC++/Fortran compiler failed ...
Rajeev Thakur thakur at mcs.anl.gov
Tue Jun 30 09:40:42 CDT 2009
It is failing at the point where the Fortran compiler is invoked.
Does it build without shared libraries, i.e., regular build with Intel
compiler?
Rajeev
  _____
[mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Seifer Lin
Sent: Tuesday, June 30, 2009 3:42 AM
Subject: [mpich-discuss] build MPICH2-1.1 (shared libs) with
Hi
I use the following command to build MPICH2-1.1 with GNU compiler
./configure CFLAGS="-fPIC" CXXFLAGS="-fPIC" FFLAGS="-fPIC"
--enable-sharedlibs=gcc --enable-mpe --with-device=ch3:nemesis
--with-pm=smpd --with-pmi=smpd
and everything is fine!
but when I use
export CC=icc
export CXX=icpc
export FC=ifort
export F77=ifort
export F90=ifort
a make error occurrs!
  CC              null_comm_del_fnf.c
  CC              null_comm_copy_fnf.c
  CC              dup_win_fnf.c
  CC              null_win_del_fnf.c
  CC              null_win_copy_fnf.c
  CC              dup_type_fnf.c
  CC              null_type_del_fnf.c
  CC              null_type_copy_fnf.c
  CC              statusf2c.c
  CC              statusc2f.c
  CC              setbot.c
  FC              setbotf.f
make[4]: *** [setbotf.lo] Error 1
make[4]: Leaving directory
`/home/seifer/mpich2-1.1_x64_smpd_intelbuild_dynamic/src/binding/f77'
make[3]: *** [all-redirect] Error 1
make[3]: Leaving directory
make[2]: *** [all-redirect] Error 1
make[2]: Leaving directory
`/home/seifer/mpich2-1.1_x64_smpd_intelbuild_dynamic/src/binding'
make[1]: *** [all-redirect] Error 2
make[1]: Leaving directory
`/home/seifer/mpich2-1.1_x64_smpd_intelbuild_dynamic/src'
make: *** [all-redirect] Error 2
Does anyone build MPICH2-1.1+icc/ifort+enable-sharedlibs=gcc
successfully ?
regards,
Seifer
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20090630/889d476d/attachment.htm>
