[mpich-discuss] Problem using Mpich2 on Vista machines
Jayesh Krishna jayesh at mcs.anl.gov
Wed Jun 24 15:00:50 CDT 2009
# Is SMPD installed on all the machines (Does "smpd -status" show that
SMPD is running on all the machines)?
# Can you try specifying an ipaddress instead of a hostname while running
your job (mpiexec -n 2 -host IPADDRESS_OF_HOST hostname)?
Jayesh
  _____
[mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Fairchild, Jack
Sent: Wednesday, June 24, 2009 2:44 PM
Subject: Re: [mpich-discuss] Problem using Mpich2 on Vista machines
Thanks for the quick response Larry.  Windows fire wall is off.  I can
ping the machines, and can access the machines through explorer.  The pass
phrases are all the same "behappy" and since it's all networked, my login
and passwords are the same.  Just in case, I did run the smpd -register
command to no avail.  We're attempting to work around the problem now by
cloning one of the working hard drives.
Jack Fairchild
[mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Larry Adams
Sent: Wednesday, June 24, 2009 3:37 PM
Jack,
Try the firewall first, you have to unblock the smpd service port.  Beyond
that, you have to verify that smpd service is installed,  and if it's
another host, you will either have to register a pass phrase, or your
account on the execution node to be able to continue.  If your password
ever changes, you have to re-perform this step.
Larry Adams
Senior Systems Engineer
Platform Computing
Tele: (586) 510-0007
Cell: (586) 899-1138
Skype: TheWitness
  _____
Sent: Wednesday, June 24, 2009 3:26 PM
Subject: [mpich-discuss] Problem using Mpich2 on Vista machines
I've debugged as far as I can:
Invoking the command: mpiexec -validate -host myhost  returns:
Aborting: connection to smpd rejected
Invoking mpiexec -file myfile  returns:
Aborting: unable to connect to myhost
Some background.
All computers are running Vista Ultimate.  The computers are connected by
a 100mbs LAN.  A few months ago, I set up 4 machines for this use.  They
all still connect without issue.
At this point I need to add some more, but am getting these errors.  All
machines have smpd version 1.0.8.  I am an administrator on all machines,
and installed Mpich2 as the administrator.  UAC was turned off and remains
off, all known firewalls are also off.  A path variable to the bin
directory  was added.
I ran smpd -d and all of the parameters match those of the working
computers.
What am I missing here?  I appreciate your valuable time.
Jack Fairchild
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20090624/0adedec0/attachment.htm>
