[mpich-discuss] CPI test fails under Fedora 10
    peter_raeth at juno.com
    Wed Jun 24 05:04:33 CDT 2009
It might be easier to run "make check" from the src/openpa/
directory.  That should run all the openpa tests.
-Dave
On Jun 23, 2009, at 4:31 PM, Darius Buntinas wrote:
> Hmm, still not sure why you can't compile test_barriers.  Let's try
> this:
> cd /home/Guest/Download/mpich2-1.1/src/openpa
> ls
> ./configure
> make
> cd test
> ls
> make test_barriers
> ./test_barriers
> Thanks,
> -d
Was unable to run "make check" from the unpack directory but was able to do so from the tmp directory. Attached is the console output from that attempt.
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20090624/ee893dcd/attachment.htm>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20090624/ee893dcd/attachment.txt>
