[mpich-discuss] CPI test fails under Fedora 10
    Deji Akingunola
    dakingun at gmail.com
    Fri Jun 19 22:26:36 CDT 2009
On Fri, Jun 19, 2009 at 3:45 PM,
peter_raeth at juno.com<peter_raeth at juno.com> wrote:
> Today I started fresh. Downloaded Fedora 10 i386 and installed it on a
> different machine. The install processes completely reformatted the disk
> before installing anything. This machine is not connected to a network.
> Then I installed mpich2-1.1 by following the installer guide pp 2-6, all
> steps through step 11. All steps went well. No RPMs were used, just the
> source.
Can you also test with installing the MPICH2 rpms ('just run "yum
install mpich2*"), after you've removed (or moved aside) your
previously self-built copy?
Deji
