[mpich-discuss] coll_test.c
Rob Latham
robl at mcs.anl.gov
Mon Jun 8 10:43:36 CDT 2009
On Fri, Jun 05, 2009 at 06:37:16PM -0500, Wei-keng Liao wrote:
> In romio/test/coll_test.c, the same fileview is used for both write and
> read.
> Some errors may not be detected.
> I suggest to add the following code segment between write and read to
> check
> the entire file contents before the read. (between lines 154 and 155)
That's a good suggestion. At first I was worried that the amount of
data would be too much for rank 0, but then I saw the test initializes
the dataset by allocating an array of that size anyway. (Plus, 128K
is hardly excessive, and even a 64x64x64 darray of doubles would still
be 2 gigs.)
The one tweak I made was to increment the error count when rank 0
verifies the write and finds a discrepancy.
Thanks for the contribution! I've checked this in as r4673
==rob
Rob Latham
Mathematics and Computer Science Division
Argonne National Lab, IL USA
