[mpich-discuss] IMB fails with tcp/ip 512 processes.
    Dhabaleswar Panda
    panda at cse.ohio-state.edu
    Wed Jun  3 06:48:31 CDT 2009
If you are interested in the TCP/IP interface, you should use the latest
MPICH2 stack (not MVAPICH2 stack). FYI, the TCP/IP interface support in
MVAPICH2-1.2 is similar to that in MPICH2 1.0.7. We released MVAPICH2 1.4
yesterday and it has the TCP/IP support of MPICH2 1.0.8p1.  The latest
version of MPICH2 stack is the 1.1 series. You should use this version to
get the best performance and stability.
Hope this helps.
DK
On Wed, 3 Jun 2009, Devesh Sharma wrote:
> Hello list
> I am trying to run IMB using ssm ADI of MVAPICH2-1.2 on 32 quad socket
> quad core machines. But it is failing because segfault when I run with
> 512 processes.
> Somebody kindly help me to figure out where the problem is.
> -Devesh
