[mpich-discuss] ad_pvfs2_read bug in ADIOI_PVFS2_ReadStrided()
Rob Latham
robl at mcs.anl.gov
Mon Jun 1 14:33:45 CDT 2009
On Fri, May 29, 2009 at 07:01:31PM -0500, Wei-keng Liao wrote:
> I suspect there is a bug at line 480, file ad_pvfds2_read.c.
> Here is the test case. Each process defines a noncontiguous fileview
> using MPI_Type_vector() and MPI_File_read_all() reads an amount
> that is less than the size of first contiguous block in fileview.
Hi Wei-keng. Thanks for the test case.
Could you take a look at the attached patch? I tried to handle all
the cases in the most straightforward way. I'll follow up on the
other part of your question after i get done with this meeting:
With these changes I pass your test case with two processors, and the
ROMIO test suite passes all tests.
May I add vector-read to the suite?
Thanks
==rob
Rob Latham
Mathematics and Computer Science Division
Argonne National Lab, IL USA
Type: text/x-diff
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20090601/ac7bd16b/attachment.bin>
