[mpich-discuss] MPICH2 on Mac OS x86-64
    Dmitry Nedospasov
    russo at cs.tu-berlin.de
    Mon Jun  1 11:14:39 CDT 2009
Okay I'm assuming the -m64 CFLAGS is what I wanted, so thanks for
that, but now i get the error that my fortran compiler is incompatibel
with my GCC
D.
$ export CFLAGS=-m64; ./configure --prefix=/Users/russo/build/mpich2 --
enable-sharedlibs=osx-gcc
Configuring MPICH2 version 1.1rc1 with  '--prefix=/Users/russo/build/
mpich2' '--enable-sharedlibs=osx-gcc' 'CFLAGS=-m64'
Running on system: Darwin kovalchuk.nedos.net 9.7.0 Darwin Kernel
Version 9.7.0: Tue Mar 31 22:52:17 PDT 2009; root:xnu-1228.12.14~1/
RELEASE_I386 i386
Executing mpich2prereq in /Users/russo/build/mpich2-1.1rc1/src/mpid/
ch3 with
ch3/channels/nemesis
sourcing /Users/russo/build/mpich2-1.1rc1/src/pm/mpd/mpich2prereq
sourcing /Users/russo/build/mpich2-1.1rc1/src/pm/hydra/mpich2prereq
sourcing /Users/russo/build/mpich2-1.1rc1/src/pm/gforker/mpich2prereq
sourcing /Users/russo/build/mpich2-1.1rc1/src/pm/mpd/setup_pm
checking for gcc... gcc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking how to run the C preprocessor... gcc -E
checking whether the compiler defines __func__... yes
checking whether the compiler defines __FUNC__... no
checking whether the compiler sets __FUNCTION__... yes
checking whether C compiler accepts option -O2... yes
checking whether routines compiled with -O2 can be linked with ones
compiled without -O2... yes
checking for type of weak symbol alias support... no
checking whether __attribute__ ((weak)) allowed... yes
checking whether __attribute ((weak_import)) allowed... yes
checking for g77... no
checking for xlf... no
checking for f77... no
checking for frt... no
checking for pgf77... no
checking for cf77... no
checking for fort77... no
checking for fl32... no
checking for af77... no
checking for xlf90... no
checking for f90... no
checking for pgf90... no
checking for pghpf... no
checking for epcf90... no
checking for gfortran... no
checking for g95... g95
checking whether we are using the GNU Fortran 77 compiler... yes
checking whether g95 accepts -g... yes
checking whether Fortran 77 compiler accepts option -O2... yes
checking how to get verbose linking output from g95... -v
checking for Fortran 77 libraries of g95...  -L/opt/local/bin/../lib/
gcc-lib/i386-apple-darwin9.6.0/4.0.4/ -L/opt/local/bin/../lib/gcc-lib/
i386-apple-darwin9.6.0/4.0.4 -L/opt/local/lib/gcc-lib/i386-apple-
darwin9.6.0/4.0.4/ -L/usr/lib/gcc// -L/opt/local/bin/../lib/gcc-lib/
i386-apple-darwin9.6.0/4.0.4/// -L/opt/local/lib/gcc-lib/i386-apple-
darwin9.6.0/4.0.4/// -L/usr/lib// -lf95 -lm -lSystemStubs -lmx
checking whether g95 accepts the FLIBS found by autoconf... yes
checking whether C can link with  -L/opt/local/bin/../lib/gcc-lib/i386-
apple-darwin9.6.0/4.0.4/ -L/opt/local/bin/../lib/gcc-lib/i386-apple-
darwin9.6.0/4.0.4/// -L/usr/lib// -lf95 -lm -lSystemStubs -lmx... yes
checking for linker for Fortran main programs... Use Fortran to link
programs
checking whether Fortran 77 and C objects are compatible... no
checking for file... file
configure: error: ****  Incompatible Fortran and C Object File Types!
F77 Object File Type produced by "g95  -O2" is : : Mach-O object i386.
  C  Object File Type produced by "gcc -m64 -O2" is : : Mach-O 64-bit
object x86_64.
On Jun 1, 2009, at 17:30 , Rajeev Thakur wrote:
> Please send us the output of configure and make (the output printed on
> the screen).
> Rajeev
>> -----Original Message-----
>> From: mpich-discuss-bounces at mcs.anl.gov
>> [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of
>> Dmitry Nedospasov
>> Sent: Monday, June 01, 2009 6:00 AM
>> To: mpich-discuss at mcs.anl.gov
>> Subject: [mpich-discuss] MPICH2 on Mac OS x86-64
>> -----BEGIN PGP SIGNED MESSAGE-----
>> Hash: SHA1
>> Hello,
>> I'm trying to compile MPICH2 for Mac OS, but the subsequent
>> mpi programs that i compile, complain that:
>> ld warning: in /opt/local/lib/libcrypto.dylib, file is not of
>> required architecture
>> I was curious is there a way to force the architecture to be
>> Mac OS x86-64?
>> Thanks,
>> Dmitry
>> -----BEGIN PGP SIGNATURE-----
>> Version: GnuPG v1.4.9 (Darwin)
>> iEYEARECAAYFAkojtJsACgkQdm82SADo56rOQwCeLA6ZZ6BgiSQhHaKpQH/lLeNT
>> 4cMAnjj93Tte6yfuMYXKc2ebGD96z2Ii
>> =VyjT
>> -----END PGP SIGNATURE-----
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20090601/0fa84318/attachment.htm>
Desc: This is a digitally signed message part
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20090601/0fa84318/attachment.pgp>
