[mpich-discuss] thread MPI calls
chong tan
chong_guan_tan at yahoo.com
Fri Jul 31 14:43:18 CDT 2009
I am running 1 master process and 3 slave process, master has
a recv thread, that make it 5 processes total.
THe box I have has 16 cores.
tan
Sent: Friday, July 31, 2009 12:10:21 PM
Subject: Re: [mpich-discuss] thread MPI calls
How many processes+threads do you have? It looks like you are running 1 master process (with two threads) + 3 slaves (= 5 processes/threads) on a 4-core system. Is this correct? If yes, all of these will contend for the 4 cores.
-- Pavan
On 07/30/2009 08:21 PM, chong tan wrote:
> D,
> the simplest test we have is 1 master and 3 slaves, 3 workers in total. Data szie
> start at 5K byte (1 time), then dwindles down to less than 128 byte in a hurry. THe MPI_Send/IRecv/Recv were the only ones in our application (besides from
> MPI_Init() and 1 partiticular MPI_Barrier() when the application is initialized, and 1
> Finish() ).
> do_work() has do to some amount of work, more in master proc than slave. do_litle_work()
> does what it means, in our application, it is 3 function return with int value, and 1 check for
> trace/monitor flag. (code is like "if( trace ) print_trace(..)" )
> The test was ran on a 4XQuad box, each process on its own physcial CPU. THe
> master proc (proc 0) is run on the same physical CPU as its thread. THe box
> is AMD based, so no HT (our application filters cores created by hyperthreading
> by default). on the 3 workers test, we see 20% to 50% sys activity constantly. WHich in term slow
> down each proc to the point that master (proc 0)'s main thread becomes idle 40% of the time.
> In the extreme case, we saw the threaded code being 70% slower than un-threaded one.
> We have the tests ready to show the issues, it would be nice if you are around SF Bay area.
> thanks
> tan
> *From:* Darius Buntinas <buntinas at mcs.anl.gov>
> *To:* mpich-discuss at mcs.anl.gov
> *Sent:* Thursday, July 30, 2009 1:49:10 PM
> *Subject:* Re: [mpich-discuss] thread MPI calls
> OK. Yes, unless do_work and do_very_little_work make any blocking calls
> (like I/O), process 1 should have 100% cpu utilization. This should be
> fine (from a performance standpoint), as long as you aren't
> oversubscribing your processors.
> I'm going to try to reproduce your tests on our machines. How many
> worker processes do you have? Is this all on one node? If not how many
> nodes? How many cores do you have per node?
> In the mean time can you check to which processor each process is bound?
> Make sure that each process is bound to its own core, and not to a
> hyperthread.
> Thanks,
> -d
> On 07/30/2009 02:02 PM, chong tan wrote:
> > D,
> > sorry for the confusion. In our application, the setting is different
> > from the code
> > Pavan posted. I will try to have them lined up here, (<--- is between
> > thread,
> > <==== is between proc)
> > > proc 0 proc 1
> > > main thread recv thread
> > > do_work() MPI_Irecv do_work()
> > MPI_Wait*() <======= MPI_Send()
> > blocked <--- unblock > do_very_litle_work()
> > MPI_Send ==========> MPI_Recv()
> > > > I don't know if the MPI_Recv call in Proc 1 is interferring with the
> > MPI_Wait*() in Proc 1. We
> > see heavy system activity in Proc 1.
> > > > tan
> > *From:* Darius Buntinas <buntinas at mcs.anl.gov <mailto:buntinas at mcs.anl.gov>>
> > *To:* mpich-discuss at mcs.anl.gov <mailto:mpich-discuss at mcs.anl.gov>
> > *Sent:* Thursday, July 30, 2009 11:17:52 AM
> > That sounds fishy. If process 1 is doing a sleep(), you shouldn't see
> > any activity from that process! Can you double check that?
> > -d
> > On 07/30/2009 01:05 PM, chong tan wrote:
> >> pavan,
> >> the behavior you described is the expected behavior. However, using
> >> your example, we are also seeing
> >> a lot of system activity in process 1 in all of our experiments. That
> >> contributes significantly
> >> to the negative gain.
-- Pavan Balaji
http://www.mcs.anl.gov/~balaji
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20090731/0fbe93f8/attachment-0001.htm>
