[mpich-discuss] thread MPI calls
    Darius Buntinas
    buntinas at mcs.anl.gov
    Thu Jul 30 13:17:52 CDT 2009
That sounds fishy.  If process 1 is doing a sleep(), you shouldn't see
any activity from that process!  Can you double check that?
-d
On 07/30/2009 01:05 PM, chong tan wrote:
> pavan,
> the behavior you described is the expected behavior.  However, using
> your example, we are also seeing
> a lot of system activity in process 1 in all of our experiments.  That
> contributes significantly
> to the negative gain.
