[mpich-discuss] Fatal error in MPI_Init
    Luiz Carlos da Costa Junior
    lcjunior at ufrj.br
    Fri Jul 24 22:55:44 CDT 2009
Dears sirs,
I got the following message when I tried to run my code under Windows XP:
Fatal error in MPI_Init: Other MPI error, error stack:
MPIR_Init_thread(394): Initialization failed
MPID_Init(90)........: channel initialization failed
MPID_Init(357).......: PMI_Init returned -1
[0] PMI_Init failed: FAIL - init called when another process has exited
without calling init
job aborted:
rank: node: exit code[: error message]
0: amsterdam: 1: Fatal error in MPI_Init: Other MPI error, error stack:
1: amsterdam: -1073741515
2: amsterdam: -1073741515
3: amsterdam: -1073741515
4: amsterdam: -1073741515
This software can be compiled against Linux (using Intel) and Windows (using
Open Watcom).
Under Linux, it works normally.
Under Windows, I got the message above.
SMPD seems to be ok once the distributed CPI program works normally.
If I link my code with MPICH1-1.2.6 and run with "mpirun", it also works
fine.
The weird thing is that I could already make it work with
MPICH2/Windows/Open Watcom.
Do you have any clue regarding the reason of this error?
What can I be doing wrong?
Thanks in advance,
LC
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20090725/07b86bb6/attachment.htm>
