[mpich-discuss] thread MPI calls
    Dorian Krause
    ddkrause at uni-bonn.de
    Fri Jul 24 08:06:12 CDT 2009
chong tan wrote:
> box X86 box running Linux.  MPICH2 1.1 configured with
>  --disable-f77 --disable-f90 --with-device=ch3:nemesis  --enable-fast
> machine : 16 cores, load of mem.  running  with mpiexec -n 4
> The master process (MPICH rank 0) has 2 thread, main and recv, the
> locks are constructed using pthread.   The master's
> recv function wait for the recv thread to be done with all recieving,
> then process the data, and reenable the recv thread,
> like this:
>              main                                                recv
> thread
>              recvFunc() {                                   wait for
> 'run'
>              wait for read-done                          for n processes
>              apply data
> call MPI_IRecv
>              signal run                                        MPI_waitall
> signal read-done
> recvFunc is repeatedly called during the life of my applications.  (In
> a few tests I have, it is called 100+ billion times)
> compared to the same application with no thread and using IRecv or
> Recv, the threaded version can run 20+%
> slower.  From the process monitoring, it looks like the MPI Irecv
> calls maybe thread. This performance degration
> is inline with 2.0.6 configured using --enable-threads=funneled.  The
> application ran for many hours, so 20% is
> significant.
> Questions :
> -  is MPICH2 1.1 self-sensing ?  that is, does it know it can decide
> if it has to do thread-multiple ?
I'm not sure I do understand the question correctly but you have to call
MPI_Init_thread instead of MPI_Init and define the desired of level of
thread support (see p. 368 in the MPI-2.1 standard).
Dorian
> -  IRecv and MPI wait all, is that also threaded ?
> -  anyone experimented this before ?
> thanks
> tan
> *From:* Rajeev Thakur <thakur at mcs.anl.gov>
> *To:* mpich-discuss at mcs.anl.gov
> *Sent:* Friday, June 26, 2009 12:12:18 PM
> *Subject:* Re: [mpich-discuss] does 1.1 support real threading of MPI
> call ?
> Yes, it supports MPI_THREAD_MULTIPLE as defined by the MPI standard.
> Rajeev
>     *From:* mpich-discuss-bounces at mcs.anl.gov
>     [mailto:mpich-discuss-bounces at mcs.anl.gov] *On Behalf Of *chong tan
>     *Sent:* Friday, June 26, 2009 2:04 PM
>     *Subject:* [mpich-discuss] does 1.1 support real threading of MPI
>     call ?
>     Does anyone know if the 1.1 release supports real threaded MPI
>     calls.  That is,
>     a process, say 1, may contain n threads, and each calling
>     MPI_Send/Recv to
>     other processes, but still think they are all process 1 ?
>     I am not looking at the funneled solution, that does not help me.
>     thanks
>     tan
