[mpich-discuss] mpich2 and pvfs2 error
    Dorian Krause
    ddkrause at uni-bonn.de
    Fri Jul 24 07:45:53 CDT 2009
there has been a lot discussion of discussion concerning pvfs2 and
mpich2/romio on this list but I couldn't find a hint for the following
problem:
I'm working on a CentOs Rocks-distribution cluster and we have the pvfs2
roll installed (which basically set's up a pvfs2 2.7.1). The output of
pvfs2-ping shows that everything should work find and I can use all the
unix commands like ls, touch, ...
However, MPI-IO fails:
/mnt/pvfs2 kraused$ cat /home/kraused/bnchmk/Filesystem/mpio.c
#include <stdio.h>
#include <stdlib.h>
#include <mpi.h>
int main(int argc, char** argv)
    MPI_File fh;
    int      err, N;
    char     msg[MPI_MAX_ERROR_STRING];
    MPI_Init(&argc, &argv);
    if(2 != argc) {
        MPI_Abort(MPI_COMM_WORLD, 1);
    err = MPI_File_open(MPI_COMM_WORLD, argv[1], MPI_MODE_WRONLY |
MPI_MODE_CREATE /* | MPI_MODE_UNIQUE_OPEN */, MPI_INFO_NULL, &fh);
    printf(" MPI_File_open returned %d\n", err);
    MPI_Error_string(err, msg, &N);
    printf(" MPI_Error_string(%d) = %s\n", err, msg);
    MPI_File_close(&fh);
    return MPI_Finalize();
/mnt/pvfs2 kraused$ /home/kraused/mpich2-1.1.1/bin/mpiexec -np 1
/home/kraused/bnchmk/Filesystem/mpio pvfs2:///mnt/pvfs2/abc
[E 14:42:04.891854] invalid (NULL) required argument
[E 14:42:04.891992] PVFS_isys_create call: Invalid argument
[E 14:42:04.892686] invalid (NULL) required argument
[E 14:42:04.892717] PVFS_isys_create call: Invalid argument
 MPI_File_open returned -524286
 MPI_Error_string(-524286) = Undefined dynamic error code
The problem seams to be the creation of new files as touching and
afterwards opening works:
/mnt/pvfs2 kraused$ touch abc
 MPI_File_open returned 0
 MPI_Error_string(0) = No MPI error
The mpich2 version is 1.1.1 and the configure flags are
./configure --prefix=/home/kraused/mpich2-1.1.1 --enable-romio
--with-file-system=pvfs2+ufs+nfs CFLAGS=-I/usr/local/src/pvfs-2.8.1/include/
Any hints/ideas where to look at?
Dorian
