[mpich-discuss] Overflow in MPI_Aint
Joe Ratterman jratt at us.ibm.com
Tue Jul 21 13:06:51 CDT 2009
Christina,
Blue Gene/P is a 32-bit platform where we have hit similar problems.  To get
around this, we increased the size of MPI_Aint in MPICH2 to be larger than
void*, to 64 bits.  I suspect that your test case would work on our system,
and I would like to see your test code if that is possible.  It should run
on our system, and I would like to make sure we have it correct.
If you are interested, we have patches against 1.0.7 and 1.1.0 that you can
use (we skipped 1.0.8).  If you can build MPICH2 using those patches, you
may be able to run your application.  On the other hand, they may be too
specific to our platform.  We have been working with ANL to incorporate our
changes into the standard MPICH2 releases, but there isn't a lot of demand
for 64-bit MPI-IO on 32-bit machines.
Joe Ratterman
IBM Blue Gene/P Messsaging
jratt at us.ibm.com
On Fri, Jul 17, 2009 at 7:12 PM, Christina Patrick <
christina.subscribes at gmail.com> wrote:
> Hi Pavan,
> I ran the command
> $ getconf | grep -i WORD
> WORD_BIT=32
> So I guess it is a 32 bit system.
> Thanks and Regards,
> Christina.
> On Fri, Jul 17, 2009 at 8:06 PM, Pavan Balaji<balaji at mcs.anl.gov> wrote:
> > Is it a 32-bit system? MPI_Aint is the size of a (void *), so on 32-bit
> > systems it's restricted to 2GB.
> >  -- Pavan
> > On 07/17/2009 07:04 PM, Christina Patrick wrote:
> >> Hi Everybody,
> >> I am trying to create an array 32768 x 32768 x 8 bytes(double) = 8GB
> >> file using 16 MPI processes. However, everytime, I try doing that, MPI
> >> aborts. The backtrace is showing me that there is a problem in
> >> ADIOI_Calc_my_off_len() function. There is a variable there:
> >> MPI_Aint filetype_extent;
> >> and the value of the variable is filetype_extent = 0 whenever it
> executes
> >> MPI_Type_extent(fd->filetype, &filetype_extent);
> >> Hence, when it reaches the statement:
> >>    335             n_filetypes  = (offset - flat_file->indices[0]) /
> >> filetype_extent;
> >> I always get SIGFPE. Is there a solution to this problem? Can I create
> >> such a big file?
> >> I checked the value of the variable while creating a file of upto 2G
> >> and it is NOT zero which makes me conclude that there is an overflow
> >> when I am specifying 8G.
> >> Thanks and Regards,
> >> Christina.
> >> PS: I am using the PVFS2 filesystem with mpich2-1.0.8 and pvfs-2.8.0.
> > Pavan Balaji
> > http://www.mcs.anl.gov/~balaji
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20090721/80611b2c/attachment.htm>
