[mpich-discuss] building libraries
    samantha lin
    wl8150 at googlemail.com
    Sat Jul 18 16:51:55 CDT 2009
Thanks for the reply.
It now steps further according to your suggestions and also
the error messages. I added two more parameters:
 --host xsim --with-cross=xc_datatypes
The file, xc_datatypes, is generated by compiling the program
maint/getcross.c .
The configuration now stops at an error:
configure: error: No timer found
Anyone has ideas?
wl
On Sat, Jul 18, 2009 at 10:12 PM, Pavan Balaji <balaji at mcs.anl.gov> wrote:
> This part is actually done by autoconf, and not by MPICH2 itself. So, I
> don't know how it can be changed. Maybe some autoconf experts can chime in?
> In the meanwhile, is there a way for you to change the compiler's default
> output name? One way is to create a wrapper that does something like:
>  $ cat wrapper_cc
> xcc $@ && if [ -e a.xe ] ; then mv a.xe a.out ; fi
> This will create an "a.out" output file instead of "a.xe".
>  -- Pavan
> On 07/18/2009 04:01 PM, samantha lin wrote:
>> The compilation is done correctly and the output file is "a.xe" rather
>> than "a.out".
>> Moreover, the executable file should run on a simulator.
>> That is:
>> $xsim a.xe
>> Is it possible to change the configure to get this supported?
>> wl
>> On Sat, Jul 18, 2009 at 9:44 PM, Pavan Balaji <balaji at mcs.anl.gov<mailto:
>> balaji at mcs.anl.gov>> wrote:
>>    Does this simple problem work correctly for you:
>>    $ cat conftest.c
>>    int main()
>>           return 0;
>>    $ xcc -target=XS1-G4B-FB512 conftest.c
>>    $ ./a.out
>>     -- Pavan
>>    On 07/18/2009 03:39 PM, samantha lin wrote:
>>        Hi,
>>        Sorry, still got problem when re-building the libraries. Here is
>>        the error message:
>>        checking for C compiler default output file name... configure:
>>        error: C compiler cannot create executables
>>        See `config.log' for more details.
>>        The compiler should be able to produce executables as I saw
>>        a file generated which is "a.xe".  I added the log file to this
>>        email. Hope someone can help. Thanks.
>>        wl
>>        On Sat, Jul 18, 2009 at 8:17 PM, Pavan Balaji
>>        <balaji at mcs.anl.gov <mailto:balaji at mcs.anl.gov>
>>        <mailto:balaji at mcs.anl.gov <mailto:balaji at mcs.anl.gov>>> wrote:
>>           To replace the C compiler with foo, you can do
>>            $ CC=foo ./configure
>>           For C++, Fortran 77 and Fortran 90, you can use CXX, F77 and F90
>>           respectively.
>>            -- Pavan
>>           On 07/18/2009 02:04 PM, samantha lin wrote:
>>               Hi,
>>               Is it possible to build the mpi libraries by a compiler
>>        which isn't
>>               assigned by the configure file?
>>               Thanks,
>>               WL
>>           --    Pavan Balaji
>>           http://www.mcs.anl.gov/~balaji
>>    --    Pavan Balaji
> Pavan Balaji
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20090718/4ecdf777/attachment.htm>
