[mpich-discuss] building libraries
    samantha lin
    wl8150 at googlemail.com
    Sat Jul 18 15:39:55 CDT 2009
Sorry, still got problem when re-building the libraries. Here is the error
message:
checking for C compiler default output file name...
configure: error: C compiler cannot create executables
See `config.log' for more details.
The compiler should be able to produce executables as I saw
a file generated which is "a.xe".  I added the log file to this email. Hope
someone can help. Thanks.
wl
On Sat, Jul 18, 2009 at 8:17 PM, Pavan Balaji <balaji at mcs.anl.gov> wrote:
> To replace the C compiler with foo, you can do
>  $ CC=foo ./configure
> For C++, Fortran 77 and Fortran 90, you can use CXX, F77 and F90
> respectively.
>  -- Pavan
> On 07/18/2009 02:04 PM, samantha lin wrote:
>> Hi,
>> Is it possible to build the mpi libraries by a compiler which isn't
>> assigned by the configure file?
>> Thanks,
>> WL
> Pavan Balaji
> http://www.mcs.anl.gov/~balaji
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20090718/12043f91/attachment.htm>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20090718/12043f91/attachment.obj>
