[mpich-discuss] I wonder if my mpdboot is the causeofproblem...help me!
Rajeev Thakur
thakur at mcs.anl.gov
Sat Jul 18 10:42:03 CDT 2009
Are the CPUs identical on them? Is one 32-bit, the other 64-bit?
_____
[mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Gra zeus
Sent: Saturday, July 18, 2009 10:27 AM
Subject: Re: [mpich-discuss] I wonder if my mpdboot is the
one of them is quad core and another one is dual core. however,
OS,account,my password,install path are all the same.
I use this configuration "./configure
--prefix=/opt/localhomes/myname/mpich2-install" in both machines.
--- On Sat, 7/18/09, Rajeev Thakur <thakur at mcs.anl.gov> wrote:
Subject: Re: [mpich-discuss] I wonder if my mpdboot is the cause
Date: Saturday, July 18, 2009, 7:02 AM
What are the exact parameters you passed to configure when building
MPICH2? Are the two machines identical?
Rajeev
_____
Sent: Saturday, July 18, 2009 12:06 AM
Subject: [mpich-discuss] I wonder if my mpdboot is the cause
hello,
thx for answer yesterday.
I tested my code in one machine (with"mpiexec -n 2 ./myprog"),everything
work fine - my program can use MPI_Send,MPI_Recv without any problems.
today, I setup mpich2 on two machines. Both machines can communicate
with others, ssh are tested on both machines, mpd work, mpdringtest
work.
however,when i run my program that use MPI_Send and MPI_Recv, MPI_Recv
is blocked forever.
so i write new simple code to test MPI_Send,MPI_Recv like this
int myrank;
MPI_Status status;
MPI_Init( &argc, &argv );
MPI_Comm_rank( MPI_COMM_WORLD, &myrank );
if (myrank == 0)
int senddata = 1;
MPI_Send(&senddata, 1, MPI_INT, 1, 0, MPI_COMM_WORLD);
else if (myrank == 1)
int recvdata = 0;
MPI_Recv(&recvdata, 1, MPI_INT, 0, 0, MPI_COMM_WORLD, &status);
printf("received :%d:\n", recvdata);
MPI_Finalize();
i got this error
Assertion failed in file ch3_progress.c at line 489: pkt->type >= 0 &&
pkt->type < MPIDI_NEM_PKT_END
internal ABORT - process 1
Fatal error in MPI_Finalize: Other MPI error, error stack:
MPI_Finalize(315)..................: MPI_Finalize failed
MPI_Finalize(207)..................:
MPID_Finalize(92)..................:
PMPI_Barrier(476)..................: MPI_Barrier(comm=0x44000002) failed
MPIR_Barrier(82)...................:
MPIC_Sendrecv(164).................:
MPIC_Wait(405).....................:
MPIDI_CH3I_Progress(150)...........:
MPID_nem_mpich2_blocking_recv(1074):
MPID_nem_tcp_connpoll(1667)........:
state_commrdy_handler(1517)........:
MPID_nem_tcp_recv_handler(1413)....: socket closed
I also tried example/cpi that come with install package -> result is the
example program freezed, without any errors.(I assume it stopped at
MPI_Bcast())
Can anyone help me with this?
This code and my program can run smoothly when I use 1 machine (with
option , -n 2, -n 4 .... etc) but whenever I start mpdboot with 2
machines, mpi processes can't communicate with other mpi processes via
MPI_Send,MPI_Recv.
thx,
gra
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20090718/dafaa0fb/attachment-0001.htm>
