[mpich-discuss] Please Help Me! - Unable to register username/password with mpiexec on windows
Jayesh Krishna
jayesh at mcs.anl.gov
Fri Jul 17 13:39:28 CDT 2009
You should find the source code for a sample MPI program, cpi, in the
examples directory of your MPICH2 installation (C version of cpi - icpi.c,
C++ version of cpi - cxxpi.cxx). The directory should also contain a
compiled version of cpi, cpi.exe (mpiexec -n 2 cpi.exe).
Do you still get the error message when you run your MPI jobs? Are you
able to validate the username/password (mpiexec -validate) after
registering it (mpiexec -register)?
Jayesh
_____
From: reza hashemi kahnamoei [mailto:reza.hashemik at gmail.com]
Sent: Friday, July 17, 2009 1:21 PM
To: Jayesh Krishna
Subject: Re: Please Help Me! - Unable to register username/password with
mpiexec on windows
I installed the MPICH2 as a administrator and specified it in "Everyone".
Can you send me an mpi c++ program? for example the factoriel program!
thank's
On Fri, Jul 17, 2009 at 2:32 AM, Jayesh Krishna <jayesh at mcs.anl.gov>
wrote:
Did you install MPICH2 as the administrator ? If so, did you specify that
MPICH2 is to be used by all users (The default is "Just me", you need to
select "Everyone" when installing MPICH2) ? Try re-installing MPICH2
making sure that you install MPICH2 for all users (Select "Everyone" when
prompted for while installing MPICH2).
(PS: Since the problem does not appear to be a bug we can discuss your
issue in the mpich-discuss mailing list. If we feel there is a bug in the
code we can re-open the ticket 717.)
Jayesh
EXCUSE ME! My English Is Very Low Level. EXCUSE ME!
I do this jobs that you said:
# Make sure you have the same user (reza) on both the machines and that
they have the same password (Assuming reza is not a domain user).
# Register your username/password using "-register" option of mpiexec
WITHOUT the "-user" option (mpiexec -register).
# Run your MPI jobs WITHOUT the "-user" option (mpiexec -n 2 cpi.exe)
# Use wmpiconfig if needed.
But it errored me!
Error is it " Credentials for reza rejected connecting to PC1
Aborting: Unable to connect to PC1 "
At first time I want to perform this statement "mpiexec -n 2 cpi.exe" it
errored!
But after I perform this statement "mpiexec -user 1 -n 2 cpi.exe"
username:administrator
password:administrator password.
the cpi is runing!
After Performing above statement I do this job:
I type this statement : "mpiexec -n 2 cpi.exe"
mpi not errored and running the cpi.exe!
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20090717/5b5a05a3/attachment.htm>
