[mpich-discuss] integrating mpich into MS Visual Studio for debugging FORTRAN
michael
michael.bane at manchester.ac.uk
Wed Jul 8 08:38:22 CDT 2009
With thanks to Jayesh, and tips I've garnered from elsewhere (and
learning by mistake!), I've pulled together a short example on using
MS Visual Studio for debugging MPI under MS Windows and would welcome
any comments re mistakes or omissions:
http://wiki.rcs.manchester.ac.uk/community/MPI/VisualStudio_mpich2_howto
Many thanks, Michael, Research Computing Services, University of
Manchester, United Kingdom
> Comment (by Jayesh Krishna):
> Hi,
> Take a look at the section 9.8 in the window's developer's guide
(http://www.mcs.anl.gov/research/projects/mpich2/documentation/index.php?s
> =docs) on debugging MPI programs.
Had seen above but didn't seem to meet the requirements of doing it
within the V.S. IDE... however:
> # You can also attach to MPI programs that are running using the VS
> debugger ("Attach to process").
ah, didn't try the above... but also:
> # If all the MPI processes are launched on the same machine/node
> then you
> can start smpd in debug mode (smpd -stop; smpd -d;) and use multiple
> instances of VS to start your MPI program (mpiexec -n 2 devenv.exe
> fpi.exe
> ==> will start two VS windows and you can step individually through
> them).
yes! this seems similar to what I was looking for (but prefer to be
able to kick off from the VS IDE itself!)
> (PS: The debug versions of MPICH2 libraries, eg: fmpich2d.lib, is
only
> required if you are debugging the MPICH2 library.)
good point and many thanks for pointing that out ;)
M
> Regards,
> Jayesh
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20090708/ed3e75a8/attachment.htm>
