[mpich-discuss] change the rank ordering
Dorian Krause
ddkrause at uni-bonn.de
Sat Jul 4 06:29:36 CDT 2009
A cartesian communicator essentially defines a 1-to-1 mapping
{ 0, ..., numprocs-1} <-> { 0, ..., dim[0]-1} x { 0, ..., dim[1]-1 }
so it should be no problem to define it yourself, e.g.
coord[0] = myrank % dim[0]
coord[1] = myrank - dim[1]*coord[0]
You could then create your own MPI like funktions, i.e.
MyMPI_Cart_get() ...
MPI might also reorder your nodes so that this virtual topology matches
the underlying physical topology (e.g. the Torus network on BG). This
might increase performance, but I suspect that on commodity hardware
this doesn't matter?!
Dorian
Rolf Kuiper wrote:
> Sounds great! But how?
> Rolf
> Am 04.07.2009 um 04:40 schrieb Rajeev Thakur:
>> As pg 243 of the MPI 2.1 standard says, MPI assumes a row-major
>> ordering of processes for cartesian topologies. If you need a
>> different ordering such as column major, you probably don't want to
>> use the cartesian topology functions. You can do the mapping yourself.
>> Rajeev
>> *From:* mpich-discuss-bounces at mcs.anl.gov
>> [mailto:mpich-discuss-bounces at mcs.anl.gov] *On Behalf Of *Rolf Kuiper
>> *Sent:* Friday, July 03, 2009 3:32 PM
>> *To:* mpich-discuss at mcs.anl.gov <mailto:mpich-discuss at mcs.anl.gov>
>> *Subject:* [mpich-discuss] change the rank ordering
>> Hi MPICH-users,
>> to merge to applications I have to create a communicator with
>> coordinates in a reversed ordering of the coordinates than the
>> default in MPI.
>> E.g.: The default MPI layout sets the ranks of the communicators
>> to first in z than in y than in x direction, like:
>> y
>> | 2-4-6
>> | 1-3-5
>> |--------> x
>> Now I want to change the ordering to loop first in x than in y, like:
>> y
>> | 4-5-6
>> | 1-2-3
>> |--------> x
>> So far I can create a cartesian communicator and test its coords
>> with
>> int dims[3] = {0,0,0};
>> int ndims=3;
>> MPI_Dims_create(NumberOfProcessors, ndims, dims);
>> int false = 0; int true = 1;
>> int periods[3] = { false, false, true };
>> int reorder = true;
>> MPI_Comm MyComm;
>> MPI_Cart_create(MPI_COMM_WORLD, ndims, dims, periods, reorder,
>> &MyComm);
>> MPI_Cart_coords(MyComm, LocalRank, ndims, coords);
>> But how can I get access to change either the current rank or the
>> associated coords?
>> Thanks for your help in advance,
>> Rolf
