[mpich-discuss] Error
    Jayesh Krishna
    jayesh at mcs.anl.gov
    Wed Jul  1 12:00:20 CDT 2009
  "Subscript out of range for array itab_w
(/rstor/xzhang/olam/3.0/modules/mem_sflux.f90: 270) " Are you accessing an
array element which is out of range (Most of the fortran compilers allow
you to check "array and string bounds")?
Jayesh
  _____
[mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of
littledddna at gmail.com
Sent: Wednesday, July 01, 2009 9:58 AM
Subject: [mpich-discuss] Error
HI~ everyone ~ I met this error when I use MPICH version2
The error is like:
Fatal error in MPI_Send: Other MPI error, error stack:
MPI_Send(173)...............................: MPI_Send(buf=0x8a550d0,
count=2, MPI_INTEGER, dest=10, tag=10, MPI_COMM_WORLD) failed
MPIDI_CH3_Progress_wait(212)................: an error occurred while
handling an event returned by MPIDU_Sock_Wait()
MPIDI_CH3I_Progress_handle_sock_event(772)..:
MPIDI_CH3_Sockconn_handle_connect_event(589): [ch3:sock] failed to
connnect to remote process
MPIDU_Socki_handle_connect(791).............: connection failure
(set=0,sock=1,errno=111:Connection refused)
0: Subscript out of range for array itab_w
subscript=-1, lower bound=1, upper bound=7887, dimension=1
[cli_23]: aborting job:
count=2, MPI_INTEGER, dest=26, tag=10, MPI_COMM_WORLD) failed
(set=0,sock=4,errno=111:Connection refused)
subscript=-1, lower bound=1, upper bound=7689, dimension=1
[cli_27]: aborting job:
What does this error mean? I totally got no clues....
Thank you very much
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20090701/23aefc23/attachment.htm>
