[mpich-discuss] MPICH2-1.1 + PVFS-2.8.1 installation problem
    Rob Latham
    robl at mcs.anl.gov
    Wed Jul  1 09:35:38 CDT 2009
On Tue, Jun 30, 2009 at 08:31:10PM -0400, Shawn Kim wrote:
> Hi,
> I installed PVFS-2.8.1 and MPICH2-1.1 correctly (I believe).
> MPICH2 configuration options:
> $ ./configure --enable-romio --enable-threads=multiple --enable-debuginfo
> --enable-g=dbg --prefix=$MYHOME/mpich2-install/
> --with-pvfs2=$MYHOME/pvfs-2.8.1 --with-file-system=ufs+nfs+pvfs2 |& tee
> c.txt
> I could compile mpich2-1.1 with the above option successfully,  but whenever
> I try to run a sample program, errors occured.
> $mpirun -n 2 mpi-io-test
> rank 1 in job 3  aum10.cse.psu.edu_41952   caused collective abort of all
> ranks
>   exit status of rank 1: killed by signal 9
> rank 0 in job 3  aum10.cse.psu.edu_41952   caused collective abort of all
> ranks
>   exit status of rank 0: killed by signal 4
> Is there anybody who know this error?
I know of no reason why pvfs-2.8.1 and mpich2-1.1 should fail to work.
Did you get a core file from those signals?  Can you post a stack
trace?
> In addition, I couldn't compile with the following option. I mean I could
> finish "./configure" successfully, but when make, error happened. The only
> difference is "--enable-g=all" instead of "--enable-debuginfo --enable-g=dbg
> $ ./configure --prefix=$MYHOME/mpich2-install/
> --with-pvfs2=$MYHOME/pvfs-2.8.1 --enable-romio --enable-threads=multiple
> --with-file-system=nfs+ufs+pvfs2 --enable-g=all |& tee c.txt**
> Error message:
> $ make
> ../../../../../lib/libmpich.a(trmem.o)(.text+0x24c): In function
> `MPIU_trvalid_unsafe':
> /home/mdl/seokim/mpich2-1.1+pvfs-2.8.1/mpich2-1.1/src/util/mem/trmem.c:523:
> undefined reference to `VALGRIND_MAKE_MEM_NOACCESS'
I'll let the other MPICH2 folks weigh in on that one.  Typically those
trmem warnings kick in when you call malloc/calloc/realloc/free
directly instead of through the memory management wrappers.
==rob
Rob Latham
Mathematics and Computer Science Division
Argonne National Lab, IL USA
