[mpich-discuss] unable to connect ?
    kiss attila
    kissattila2008 at gmail.com
    Fri Feb 27 11:16:08 CST 2009
S U C C E S S ! ! !
 Thanks a lot. Probably i've played with instalation settings and
modified the passphrase, but now it works :).
Hmmm.... a strange thing: the cpi.exe runs with the same input in
1,872297s running on both machines,  1,869439s running on 10.0.0.13
and 1.897818s runnning on 10.0.0.10. I thought running on two machines
would be the fastest.
mpiexec with the -log switch shouldn't create some logfile? I can't
find any logfiles in the mpich2 folders.
 regards
K.A. Albert
2009/2/27 Jayesh Krishna <jayesh at mcs.anl.gov>:
>  Hi,
>   From your debug logs the problem does not appear to be a network
> connectivity issue. It looks more like a configuration issue,
> ============== snip ========================
> ...\smpd_state_reading_connect_result
> ....read connect result: 'FAIL'
> ....connection rejected, server returned - FAIL
>   Your PM connection can get rejected due to the foll reasons,
> # There is a mismatch in the version of MPICH2 software installed on the
> multiple machines.
> # There is a mismatch in the passphrase used on the multiple machines (You
> enter this "passphrase" during MPICH2 installation).
>   I would recommend the following,
> # Uninstall MPICH2 on both the machines.
> # Download the latest stable version (1.0.8) of MPICH2 from the downloads
> page
> (http://www.mcs.anl.gov/research/projects/mpich2/downloads/index.php?s=downloads).
> # Install MPICH2 on the machines using the installer downloaded from the
> downloads page.
> ------- Make sure that you keep the default settings for passphrase during
> the installation
> ------- Also make sure that all users have access to MPICH2 (Change the
> default option from "Just me" to "Everyone" during installation)
> # If your machine is not part of a domain, when registering the
> username/password with mpiexec don't specify any domain name. Also validate,
> as before, after registering the user.
>  Let us know the results.
> (PS: There is no specific configuration required, apart from the info above,
> to get MPICH2 working across multiple windows machines)
> Regards,
> Jayesh
> -----Original Message-----
> From: kiss attila [mailto:kissattila2008 at gmail.com]
> Sent: Thursday, February 26, 2009 11:45 PM
> To: Jayesh Krishna
> Cc: mpich-discuss at mcs.anl.gov
> Subject: Re: [mpich-discuss] unable to connect ?
> Hi
>   I've tried now everything: I've created the same user, I've validated this
> user ( mpiuser ), but still nothing... Can anyone send me some config files
> from a  w o r k i n g Mpich2 setup based on windows workgroup (not domain).
> Till then these are my output from smpd -d,  and mpiexec commands, when I
> try to run from 10.0.0.10 hostname on remote computer (10.0.0.13)
> D:\Program Files\MPICH2\bin>smpd -d
> [00:2436]..\smpd_set_smpd_data
> [00:2436]../smpd_set_smpd_data
> [00:2436]..created a set for the listener: 1724 [00:2436]..smpd listening on
> port 8676 [00:2436]..\smpd_create_context [00:2436]...\smpd_init_context
> [00:2436]....\smpd_init_command [00:2436]..../smpd_init_command
> [00:2436].../smpd_init_context [00:2436]../smpd_create_context
> [00:2436]..\smpd_option_on [00:2436]...\smpd_get_smpd_data
> [00:2436]....\smpd_get_smpd_data_from_environment
> [00:2436]..../smpd_get_smpd_data_from_environment
> [00:2436]....\smpd_get_smpd_data_default
> [00:2436]..../smpd_get_smpd_data_default
> [00:2436]....Unable to get the data for the key 'no_dynamic_hosts'
> [00:2436].../smpd_get_smpd_data
> [00:2436]../smpd_option_on
> [00:2436]..\smpd_insert_into_dynamic_hosts
> [00:2436]../smpd_insert_into_dynamic_hosts
> [00:2436]..\smpd_enter_at_state
> [00:2436]...sock_waiting for the next event.
> [00:2436]...SOCK_OP_ACCEPT
> [00:2436]...\smpd_handle_op_accept
> [00:2436]....\smpd_state_smpd_listening
> [00:2436].....authenticating new connection
> [00:2436].....\smpd_create_context
> [00:2436]......\smpd_init_context
> [00:2436].......\smpd_init_command
> [00:2436]......./smpd_init_command
> [00:2436]....../smpd_init_context
> [00:2436]...../smpd_create_context
> [00:2436].....\smpd_gen_authentication_strings
> [00:2436]......\smpd_hash
> [00:2436]....../smpd_hash
> [00:2436]...../smpd_gen_authentication_strings
> [00:2436].....posting a write of the challenge string: 1.0.8 7993
> [00:2436]..../smpd_state_smpd_listening
> [00:2436].../smpd_handle_op_accept
> [00:2436]...SOCK_OP_WRITE
> [00:2436]...\smpd_handle_op_write
> [00:2436]....\smpd_state_writing_challenge_string
> [00:2436].....wrote challenge string: '1.0.8 7993'
> [00:2436]..../smpd_state_writing_challenge_string
> [00:2436].../smpd_handle_op_write
> [00:2436]...SOCK_OP_READ
> [00:2436]...\smpd_handle_op_read
> [00:2436]....\smpd_state_reading_challenge_response
> [00:2436].....read challenge response: 'd6fdd96549e0c22c875ac55a2735a162'
> [00:2436]..../smpd_state_reading_challenge_response
> [00:2436].../smpd_handle_op_read
> [00:2436]....\smpd_state_writing_connect_result
> [00:2436].....wrote connect result: 'FAIL'
> [00:2436].....connection reject string written, closing sock.
> [00:2436]..../smpd_state_writing_connect_result
> [00:2436]...SOCK_OP_CLOSE
> [00:2436]...\smpd_handle_op_close
> [00:2436]....\smpd_get_state_string
> [00:2436]..../smpd_get_state_string
> [00:2436]....op_close received - SMPD_CLOSING state.
> [00:2436]....Unaffiliated undetermined context closing.
> [00:2436]....\smpd_free_context
> [00:2436].....freeing undetermined context.
> [00:2436].....\smpd_init_context
> [00:2436]......\smpd_init_command
> [00:2436]....../smpd_init_command
> [00:2436]...../smpd_init_context
> [00:2436]..../smpd_free_context
> [00:2436].../smpd_handle_op_close
> C:\Program Files\MPICH2\bin>mpiexec -verbose -hosts 1 10.0.0.13 -user
> mpiuser hostname
> ..\smpd_add_host_to_default_list
> ...\smpd_add_extended_host_to_default_list
> .../smpd_add_extended_host_to_default_list
> ../smpd_add_host_to_default_list
> ..\smpd_hide_string_arg
> ...\first_token
> .../first_token
> ...\compare_token
> .../compare_token
> ...\next_token
> ....\first_token
> ..../first_token
> ....\first_token
> ..../first_token
> .../next_token
> ../smpd_hide_string_arg
> ...\first_token
> .../first_token
> ...\compare_token
> .../compare_token
> ...\next_token
> ....\first_token
> ..../first_token
> ....\first_token
> ..../first_token
> .../next_token
> ..\smpd_get_full_path_name
> ...fixing up exe name: 'hostname' -> '(null)'
> ../smpd_get_full_path_name
> ..handling executable:
> hostname.exe
> ..\smpd_get_next_host
> ...\smpd_get_host_id
> .../smpd_get_host_id
> ../smpd_get_next_host
> ..\smpd_create_cliques
> ...\next_launch_node
> .../next_launch_node
> ../smpd_create_cliques
> ..\smpd_fix_up_host_tree
> ../smpd_fix_up_host_tree
> ./mp_parse_command_args
> .host tree:
> . host: 10.0.0.13, parent: 0, id: 1
> .launch nodes:
> . iproc: 0, id: 1, exe: hostname.exe
> .\smpd_make_socket_loop
> ..\smpd_get_hostname
> ../smpd_get_hostname
> ./smpd_make_socket_loop
> ..SOCK_OP_CONNECT
> ..\smpd_handle_op_connect
> ...connect succeeded, posting read of the challenge string
> ../smpd_handle_op_connect ..sock_waiting for the next event.
> ..SOCK_OP_READ
> ...\smpd_state_reading_challenge_string
> ....read challenge string: '1.0.8 7993'
> ....\smpd_verify_version
> ..../smpd_verify_version
> ....\smpd_hash
> ..../smpd_hash
> .../smpd_state_reading_challenge_string
> ..SOCK_OP_WRITE
> ...\smpd_state_writing_challenge_response
> ....wrote challenge response: 'd6fdd96549e0c22c875ac55a2735a162'
> .../smpd_state_writing_challenge_response
> ..SOCK_OP_READ
> ....connection rejected, server returned - FAIL ....\smpd_post_abort_command
> .....\smpd_create_command ......\smpd_init_command ....../smpd_init_command
> ...../smpd_create_command .....\smpd_add_command_arg
> ...../smpd_add_command_arg .....\smpd_command_destination ......0 -> 0 :
> returning NULL context ...../smpd_command_destination
> Aborting: unable to connect to 10.0.0.13 ..../smpd_post_abort_command
> ....\smpd_exit .....\smpd_kill_all_processes ...../smpd_kill_all_processes
> .....\smpd_finalize_drive_maps ...../smpd_finalize_drive_maps
> .....\smpd_dbs_finalize ...../smpd_dbs_finalize
> Thanks for any ideas.
> regards
> K.A. Albert
> 2009/2/26 Jayesh Krishna <jayesh at mcs.anl.gov>:
>> Hi,
>>>>.. I launch mpiexec.exe from an another windows user acount...
>>  This could be your problem. You can try registering a
>> username/password available on both the machines using the "-user"
>> option (mpiexec -register -user 1) & launch your job using that user
>> (mpiexec -n 2 -user 1 -hosts 2 10.0.0.10 10.0.0.13 hostname). You can
>> also validate if the user credentials are capable of launching a job
>> using the "-validate" option of mpiexec (mpiexec -validate -user 1
>> 10.0.0.10 ; mpiexec -validate -user 1 10.0.0.13)
>> (PS: Did you copy-paste the complete output of the mpiexec command &
>> the command itself ? Please don't remove any part of the output. This
>> will help us in debugging your problem.)
>> Regards,
>> Jayesh
>> Sent: Thursday, February 26, 2009 12:26 AM
>> To: Jayesh Krishna
>> 1. Yes, the ping works fine. With wmpiconfig.exe i can see both machines.
>> 2. MPICH2 1.0.8 installed on both.
>> 3. No firewalls of any kind.
>> 4. On  smpd -status i get:
>> smpd running on 10.0.0.10
>> smpd running on 10.0.0.13
>> 5. from 10.0.0.10
>> C:\Program Files\MPICH2\bin>mpiexec -hosts 2 10.0.0.10 10.0.0.13
>> hostname
>> abort: unable to connect to 10.0.0.13
>> from 10.0.0.13
>> hostname
>> abort: unable to connect to 10.0.0.10
>> and here is the -verbose mode:
>> ...../first_token
>> .....\compare_token
>> ...../compare_token
>> .....\next_token
>> ......\first_token
>> ....../first_token
>> ......\first_token
>> ....../first_token
>> ...../next_token
>> ..../smpd_hide_string_arg
>> .....\smpd_option_on
>> ......\smpd_get_smpd_data
>> .......\smpd_get_smpd_data_from_environment
>> ......./smpd_get_smpd_data_from_environment
>> .......\smpd_get_smpd_data_default
>> ......./smpd_get_smpd_data_default
>> .......Unable to get the data for the key 'nocache'
>> ...../smpd_option_on
>> ....\smpd_hide_string_arg
>> .....\first_token
>> ...../first_token
>> .....\compare_token
>> ...../compare_token
>> .....\next_token
>> ......\first_token
>> ....../first_token
>> ......\first_token
>> ....../first_token
>> ...../next_token
>> ...SOCK_OP_WRITE
>> ....\smpd_state_writing_cred_ack_yes
>> .....wrote cred request yes ack.
>> ..../smpd_state_writing_cred_ack_yes
>> ...SOCK_OP_WRITE
>> ....\smpd_state_writing_account
>> .....wrote account: 'mpiuser'
>> .....\smpd_encrypt_data
>> ...../smpd_encrypt_data
>> ..../smpd_state_writing_account
>> ...SOCK_OP_WRITE
>> .....\first_token
>> ...../first_token
>> .....\compare_token
>> ...../compare_token
>> .....\next_token
>> ......\first_token
>> ....../first_token
>> ......\first_token
>> ....../first_token
>> ...../next_token
>> .....\smpd_hide_string_arg
>> ......\first_token
>> ....../first_token
>> ......\compare_token
>> ....../compare_token
>> ......\next_token
>> .......\first_token
>> ......./first_token
>> .......\first_token
>> ......./first_token
>> ....../next_token
>> ...../smpd_hide_string_arg
>> .....\first_token
>> ...../first_token
>> .....\compare_token
>> ...../compare_token
>> .....\next_token
>> ......\first_token
>> ....../first_token
>> ......\first_token
>> ....../first_token
>> ...../next_token
>> ...SOCK_OP_READ
>> ....\smpd_state_reading_process_result
>> .....read process session result: 'SUCCESS'
>> ..../smpd_state_reading_process_result
>> ...SOCK_OP_READ
>> ....\smpd_state_reading_reconnect_request
>> .....read re-connect request: '3972'
>> .....closing the old socket in the left context.
>> .....MPIDU_Sock_post_close(1720)
>> .....connecting a new socket.
>> .....posting a re-connect to 10.0.0.10:3972 in left context.
>> ..../smpd_state_reading_reconnect_request
>> ...SOCK_OP_CLOSE
>> ....Unaffiliated left context closing.
>> .....freeing left context.
>> ...SOCK_OP_CONNECT
>> ...\smpd_handle_op_connect
>> ....\smpd_generate_session_header
>> .....session header: (id=1 parent=0 level=0)
>> ..../smpd_generate_session_header .../smpd_handle_op_connect
>> ...SOCK_OP_WRITE
>> ....\smpd_state_writing_session_header
>> .....wrote session header: 'id=1 parent=0 level=0'
>> .....\smpd_post_read_command
>> ......posting a read for a command header on the left context, sock
>> 1656 ...../smpd_post_read_command .....creating connect command for
>> left node .....creating connect command to '10.0.0.13'
>> .....\smpd_add_command_int_arg
>> ...../smpd_add_command_int_arg
>> .....\smpd_post_write_command
>> ......\smpd_package_command
>> ....../smpd_package_command
>> ......smpd_post_write_command on the left context sock 1656: 65 bytes
>> for
>> command: "cmd=connect src=0 dest=1 tag=0 host=10.0.0.13 id=2 "
>> ...../smpd_post_write_command
>> .....not connected yet: 10.0.0.13 not connected
>> ..../smpd_state_writing_session_header
>> ...SOCK_OP_WRITE
>> ....\smpd_state_writing_cmd
>> .....wrote command
>> .....command written to left: "cmd=connect src=0 dest=1 tag=0
>> .....moving 'connect' command to the wait_list.
>> ..../smpd_state_writing_cmd
>> ...SOCK_OP_READ
>> ....\smpd_state_reading_cmd_header
>> .....read command header
>> .....command header read, posting read for data: 69 bytes
>> ..../smpd_state_reading_cmd_header
>> ...SOCK_OP_READ
>> .....read command
>> .....\smpd_parse_command
>> ...../smpd_parse_command
>> .....read command: "cmd=abort src=1 dest=0 tag=0 error="unable to
>> connect to 10.0.0.13" "
>> .....\smpd_handle_command
>> ......handling command:
>> ...... src  = 1
>> ...... dest = 0
>> ...... cmd  = abort
>> ...... tag  = 0
>> ...... ctx  = left
>> ...... len  = 69
>> ...... str  = cmd=abort src=1 dest=0 tag=0 error="unable to connect to
>> 10.0.0.13"
>> ......\smpd_command_destination
>> .......0 -> 0 : returning NULL context ....../smpd_command_destination
>> ......\smpd_handle_abort_command
>> .......abort: unable to connect to 10.0.0.13
>> ....../smpd_handle_abort_command ...../smpd_handle_command
>> .....\smpd_post_read_command ......posting a read for a command header
>> on the left context, sock 1656 ...../smpd_post_read_command
>> ....../smpd_init_command ...../smpd_create_command
>> .....\smpd_post_write_command ......\smpd_package_command
>> ....../smpd_package_command ......smpd_post_write_command on the left
>> context sock 1656: 43 bytes for
>> command: "cmd=close src=0 dest=1 tag=1 "
>> ...SOCK_OP_READ
>> .....command header read, posting read for data: 31 bytes
>> ...SOCK_OP_WRITE
>> .....wrote command
>> .....command written to left: "cmd=close src=0 dest=1 tag=1 "
>> .....\smpd_free_command
>> ...../smpd_free_command
>> ...SOCK_OP_READ
>> .....read command
>> .....read command: "cmd=closed src=1 dest=0 tag=1 "
>> ...... src  = 1
>> ...... dest = 0
>> ...... cmd  = closed
>> ...... tag  = 1
>> ...... ctx  = left
>> ...... len  = 31
>> ...... str  = cmd=closed src=1 dest=0 tag=1
>> ......\smpd_command_destination .......0 -> 0 : returning NULL context
>> ....../smpd_command_destination ......\smpd_handle_closed_command
>> .......closed command received from left child, closing sock.
>> .......MPIDU_Sock_post_close(1656)
>> .......received a closed at node with no parent context, assuming
>> root, returning SMPD_EXITING.
>> ....../smpd_handle_closed_command
>> .....not posting read for another command because SMPD_EXITING
>> returned ..../smpd_state_reading_cmd .../smpd_handle_op_read
>> ...SOCK_OP_CLOSE
>> ....op_close received - SMPD_EXITING state.
>> ../smpd_enter_at_state
>> ./main
>> .\smpd_exit
>> I have registered with wmpiregister.exe the same user with the same
>> password on both computers but I launch mpiexec.exe from an another
>> windows user acount; could this be a problem?. Thanks
>> regards
>> k.a.albert
>> 2009/2/25 Jayesh Krishna <jayesh at mcs.anl.gov>:
>>>  Hi,
>>> # Can you ping the machines from each other ?
>>> # Make sure that you have the same version of MPICH2 installed on
>>> both the machines.
>>> # Do you have any firewalls (windows, third-party) running on the
>>> machines (Turn off any firewalls running on the machines)?
>>> # Make sure that you have the MPICH2 process manager, smpd.exe,
>>> running as a service on both the machines (To check the status of the
>>> process manager type, smpd -status, at the command prompt).
>>> # Before trying to execute an MPI program like cpi.exe, try executing
>>> a non-MPI program like hostname on the machines (mpiexec -hosts 2
>>> 10.0.0.10
>>> (PS: In your reply please copy-paste the commands and the output)
>>> Regards, Jayesh
>>> From: mpich-discuss-bounces at mcs.anl.gov
>>> [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of kiss attila
>>> Sent: Wednesday, February 25, 2009 1:46 PM
>>> To: mpich-discuss at mcs.anl.gov
>>> Subject: [mpich-discuss] unable to connect ?
>>> Hi
>>>   I have two WinXp machines (10.0.0.13,10.0.0.10) with mpich2
>>> installed, and on this command:
>>> "D:\Program Files\MPICH2\bin\mpiexec.exe" -hosts 2 10.0.0.10
>>> 10.0.0.13 -noprompt c:\ex\cpi.exe
>>> I get:
>>> Aborting: unable to connect to 10.0.0.10
>>> Somehow I can't start any process on the remote machine(10.0.0.10).
>>> It annoys me, that a few days ago it worked, but I had to reinstall
>>> one of them, and since then i couldn't figure it out what's wrong
>>> with my settings.  thanks.
>>> regards
>>> K.A. Albert
