[mpich-discuss] Fatal error in MPI_Test: Invalid MPI_Request
Gus Correa gus at ldeo.columbia.edu
Thu Feb 26 16:57:12 CST 2009
Hi Samir
I am guessing the makefile that you are using to compile your
libbgtw library is messing up the paths to the include files.
The makefile may have some include paths hardwired that break
what mpicxx needs to do.
Otherwise mpicxx would find the right includes without a problem.
The standard and easy thing to do is to use the MPICH2
wrappers (mpicxx) to compile **both** the library and
your test program.
It is probably easier to straighten up the makefile to use
CXX=mpicxx as the C++ compiler,
than to tweak the makefile to work with CXX=g++ and do everything
exactly as mpicxx would do.
Search the makefile for "-I" directives, and also for INCLUDE or INC
strings, and things the like.  See if anything is pointing directly
to a path to mpi.h.
You may also post the makefile here.
Maybe somebody here will be able to find what is causing the problem.
I hope this helps,
Gus Correa
Gustavo Correa
Lamont-Doherty Earth Observatory - Columbia University
Palisades, NY, 10964-8000 - USA
Samir Khanal wrote:
> When i changed
> g++ to mpicxx and
> gcc to mpicc
> the compilation did complete without problem
> i can run the program with out any problem when it is standalone but when i do
> [skhanal at comet ~]$ /home/skhanal/mpich2/bin/mpicxx -L /home/skhanal/bgtw/lib -lbgtw bgtwTorusTest.cpp -o Ring
> [skhanal at comet ~]$ ./Ring
> //this works
> But when n>1 , i have problems.
> [skhanal at comet ~]$ which mpiexec
> ~/mpich2/bin/mpiexec
> [skhanal at comet ~]$ mpdringtest
> time for 1 loops = 0.00102400779724 seconds
> [skhanal at comet ~]$ mpdtrace
> comet
> compute-0-3
> compute-0-2
> compute-0-1
> compute-0-0
> compute-0-5
> compute-0-4
> [skhanal at comet ~]$ ldd ./Ring
>         libbgtw.so.0 => /home/skhanal/bgtw/lib/libbgtw.so.0 (0x00002b7b11ae4000)
>         libpthread.so.0 => /lib64/libpthread.so.0 (0x0000003614600000)
>         librt.so.1 => /lib64/librt.so.1 (0x0000003615600000)
>         libstdc++.so.6 => /usr/lib64/libstdc++.so.6 (0x0000003626000000)
>         libm.so.6 => /lib64/libm.so.6 (0x0000003613e00000)
>         libgcc_s.so.1 => /lib64/libgcc_s.so.1 (0x0000003624c00000)
>         libc.so.6 => /lib64/libc.so.6 (0x0000003613a00000)
>         /lib64/ld-linux-x86-64.so.2 (0x0000003613600000)
> [skhanal at comet ~]$ ~/mpich2/bin/mpiexec -n 2 ./Ring
> Fatal error in MPI_Test: Invalid MPI_Request, error stack:
> MPI_Test(152): MPI_Test(request=0x1c95a388, flag=0x7fff096c34d4, status=0x7fff096c3440) failed
> MPI_Test(75).: Invalid MPI_Requestrank 0 in job 8  comet.cs.bgsu.edu_60252   caused collective abort of all ranks
>   exit status of rank 0: killed by signal 9
> What am i doing wrong here?
> Samir
> From: mpich-discuss-bounces at mcs.anl.gov [mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Rajeev Thakur [thakur at mcs.anl.gov]
> Sent: Thursday, February 26, 2009 5:00 PM
> To: mpich-discuss at mcs.anl.gov
> Subject: Re: [mpich-discuss] Fatal error in MPI_Test: Invalid MPI_Request
> Make sure that particular file is being compiled with mpicc, not just gcc.
> Set the C compiler in the Makefile to mpicc.
> Rajeev
>> -----Original Message-----
>> [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Samir Khanal
>> Sent: Thursday, February 26, 2009 3:51 PM
>> MPI_Request
>> In fact i am trying to compile a library with a Make file.
>> i did as you suggested
>> #include "mpi.h"
>> It says
>> ../include/message_handler.h:17:17: error: mpi.h: No such
>> file or directory
>> BTW i have installed mpich2 in my home directory, do i need
>> to give the include directory while compiling then?
>> I think it is not finding the file in place "the current directory"
>> I am using the full path for the compiler (mpicxx)
>> Samir
>> Sent: Thursday, February 26, 2009 4:40 PM
>> MPI_Request
>> Don't even give the full path to mpi.h. Just say #include
>> "mpi.h". Give the
>> full path to mpicc   when you invoke it.
>> Rajeev
>>> Sent: Thursday, February 26, 2009 3:33 PM
>>> MPI_Request
>>> Hii Rajeev
>>> There are no mpi.h in the application directory, i am
>>> pointing to the correct directory of mpi.h
>>> (/home/skhanal/mpich2/include/mpi.h)
>>> i even renamed the mpi.h for the default installation of
>>> openmpi to mpi.h.bak
>>> But still the same problem
>>> Samir
>>> Sent: Thursday, February 26, 2009 4:31 PM
>>> MPI_Request
>>> In general, remove all your copies of mpi.h from the
>>> application directory.
>>> Let mpicc/mpif90 pick up the right mpi.h from its installation.
>>> Rajeev
>> Samir Khanal
>>>> Sent: Thursday, February 26, 2009 2:32 PM
>>>> MPI_Request
>>>> Hi Rajeev, list
>>>> I am using the mpi.h from mpich2,
>>>> the program compiled very well (i am building a library) in a
>>>> X86 box and ran without error with mpiexec 0.82 and mpich 1.2.7
>>>> I am trying to replicate the same at a x86_64 system with
>>>> mpich 1.2.7 and mpiexec 0.83
>>>> and mpich2 and its mpiexec.
>>>> The library compiles, but i get the same error as my
>> previous email.
>>>> with mpich 1.2.7 / mpiexec 0.82 i get P4 error sigx 15 error
>>>> (which Gus suggested was due to old library and i compiled
>>>> mpich2 with nemesis channel..)
>>>> with mpich2  / and its mpiexec shows  the following as a
>> job output.
>>>> This job is running on following Processors
>>>> compute-0-3 compute-0-3 compute-0-3 compute-0-3 compute-0-2
>>>> compute-0-2 compute-0-2 compute-0-2
>>>> MPI_Test(152): MPI_Test(request=0x7098388,
>>>> flag=0x7fffdda3ea34, status=0x7fffdda3e9a0) failed
>>>> MPI_Test(75).: Invalid MPI_RequestFatal error in MPI_Test:
>>>> MPI_Test(152): MPI_Test(request=0x3b95388,
>>>> flag=0x7fffb21504b4, status=0x7fffb2150420) failed
>>>> MPI_Test(75).: Invalid MPI_Requestrank 3 in job 1
>>>> compute-0-3.local_43455   caused collective abort of all ranks
>>>>   exit status of rank 3: killed by signal 9
>>>> FYI this application was written to run on a Gentoo Box with
>>>> mpich 1.2.5/7  and mpiexec (from OSC) v 0.75
>>>> I am trying to port this to a new 64bit cluster, with all
>>>> sorts of problems.
>>>> Samir
>>>> Sent: Monday, February 23, 2009 2:07 PM
>>>> MPI_Request
>>>> This can happen if you use an mpif.h or mpi.h from some other
>>>> implementation. Remove any mpi*.h in the application
>>>> directory and don't
>>>> provide any paths to mpi*.h. mpic* will pick up the right file.
>>>> Rajeev
>>> Samir Khanal
>>>>> Sent: Monday, February 23, 2009 11:35 AM
>>>>> MPI_Request
>>>>> Hi
>>>>> [skhanal at comet ~]$ g++ -v
>>>>> Using built-in specs.
>>>>> Target: x86_64-redhat-linux
>>>>> Configured with: ../configure --prefix=/usr
>>>>> --mandir=/usr/share/man --infodir=/usr/share/info
>>>>> --enable-shared --enable-threads=posix
>>>>> --enable-checking=release --with-system-zlib
>>>>> --enable-__cxa_atexit --disable-libunwind-exceptions
>>>>> --enable-libgcj-multifile
>>>>> --enable-languages=c,c++,objc,obj-c++,java,fortran,ada
>>>>> --enable-java-awt=gtk --disable-dssi --enable-plugin
>>>>> --with-java-home=/usr/lib/jvm/java-1.4.2-gcj-1.4.2.0/jre
>>>>> --with-cpu=generic --host=x86_64-redhat-linux
>>>>> Thread model: posix
>>>>> gcc version 4.1.2 20071124 (Red Hat 4.1.2-42)
>>>>> [skhanal at comet ~]$ which mpicxx
>>>>> ~/mpich2/bin/mpicxx
>>>>> [skhanal at comet ~]$ which mpicc
>>>>> ~/mpich2/bin/mpicc
>>>>> i have installed all on my home directory
>>>>> when i compile i do
>>>>> /home/skhanal/bgtw/lib -lbgtw bgtwRingTest.cpp -o Ring
>>>>> MPI_Test(152): MPI_Test(request=0x16ae9388,
>>>>> flag=0x7fff7a7599c4, status=0x7fff7a759930) failed
>>>>> the library needs a mpi.h file to include, i gave
>>>>> /home/skhanal/mpich2/include/mpi.h as an absolute path.
>>>>> any clues?
>>>>> Thanks
>>>>> Samir
>>>>> [mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Gus Correa
>>>>> [gus at ldeo.columbia.edu]
>>>>> Sent: Monday, February 23, 2009 12:32 PM
>>>>> To: Mpich Discuss
>>>>> MPI_Request
>>>>> Hi Samir, list
>>>>> I am wondering if the mpicxx and mpiexec you are using
>>>>> belong to the same MPICH2 build (considering the problems you
>>>>> reported before).
>>>>> What is the output of "which mpicxx" and "which mpiexec"?
>>>>> You may want to use full path names to mpicxx and mpiexec,
>>>>> as Anthony Chan recommended in another email.
>>>>> Problems with PATH and multiple versions and builds of MPI
>>>>> that hang around all Linux computers
>>>>> has been an endless source of frustration for many.
>>>>> I myself prefer to use full path names when I am testing
>>>>> MPI programs, to avoid any confusion and distress.
>>>>> I hope this helps,
>>>>> Gus Correa
>>>>> Gustavo Correa
>>>>> Samir Khanal wrote:
>>>>>> Hi All
>>>>>> I tried and did the following.
>>>>>> [skhanal at comet ~]$ mpicxx -L /home/skhanal/bgtw/lib -lbgtw
>>>>>> [skhanal at comet ~]$ mpiexec -n 4 ./Ring
>>>>>> MPI_Test(152): MPI_Test(request=0x1f820388,
>>>>> flag=0x7fffb8236134, status=0x7fffb82360a0) failed
>>>>>> MPI_Test(75).: Invalid MPI_Requestrank 0 in job 35
>>>>> comet.cs.bgsu.edu_35155   caused collective abort of all ranks
>>>>>> What does this mean?
>>>>>> Samir
>>>>>> Ps: I am using mpich2 1.0.8
