[mpich-discuss] Fatal error in MPI_Test: Invalid MPI_Request
Anthony Chan
chan at mcs.anl.gov
Thu Feb 26 15:58:26 CST 2009
----- "Samir Khanal" <skhanal at bgsu.edu> wrote:
> In fact i am trying to compile a library with a Make file.
> i did as you suggested
> #include "mpi.h"
> It says
> ../include/message_handler.h:17:17: error: mpi.h: No such file or
> directory
What is command that produces this error message ?
A.Chan
> BTW i have installed mpich2 in my home directory, do i need to give
> the include directory while compiling then?
> I think it is not finding the file in place "the current directory"
> I am using the full path for the compiler (mpicxx)
> Samir
> From: mpich-discuss-bounces at mcs.anl.gov
> [mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Rajeev Thakur
> [thakur at mcs.anl.gov]
> Sent: Thursday, February 26, 2009 4:40 PM
> To: mpich-discuss at mcs.anl.gov
> Subject: Re: [mpich-discuss] Fatal error in MPI_Test: Invalid
> MPI_Request
> Don't even give the full path to mpi.h. Just say #include "mpi.h".
> Give the
> full path to mpicc when you invoke it.
> Rajeev
> > -----Original Message-----
> > [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Samir
> Khanal
> > Sent: Thursday, February 26, 2009 3:33 PM
> > MPI_Request
> > Hii Rajeev
> > There are no mpi.h in the application directory, i am
> > pointing to the correct directory of mpi.h
> > (/home/skhanal/mpich2/include/mpi.h)
> > i even renamed the mpi.h for the default installation of
> > openmpi to mpi.h.bak
> > But still the same problem
> > Samir
> > Thakur [thakur at mcs.anl.gov]
> > Sent: Thursday, February 26, 2009 4:31 PM
> > MPI_Request
> > In general, remove all your copies of mpi.h from the
> > application directory.
> > Let mpicc/mpif90 pick up the right mpi.h from its installation.
> > Rajeev
> Khanal
> > > Sent: Thursday, February 26, 2009 2:32 PM
> > > MPI_Request
> > > Hi Rajeev, list
> > > I am using the mpi.h from mpich2,
> > > the program compiled very well (i am building a library) in a
> > > X86 box and ran without error with mpiexec 0.82 and mpich 1.2.7
> > > I am trying to replicate the same at a x86_64 system with
> > > mpich 1.2.7 and mpiexec 0.83
> > > and mpich2 and its mpiexec.
> > > The library compiles, but i get the same error as my previous
> email.
> > > with mpich 1.2.7 / mpiexec 0.82 i get P4 error sigx 15 error
> > > (which Gus suggested was due to old library and i compiled
> > > mpich2 with nemesis channel..)
> > > with mpich2 / and its mpiexec shows the following as a job
> output.
> > > This job is running on following Processors
> > > compute-0-3 compute-0-3 compute-0-3 compute-0-3 compute-0-2
> > > compute-0-2 compute-0-2 compute-0-2
> > > Fatal error in MPI_Test: Invalid MPI_Request, error stack:
> > > MPI_Test(152): MPI_Test(request=0x7098388,
> > > flag=0x7fffdda3ea34, status=0x7fffdda3e9a0) failed
> > > MPI_Test(75).: Invalid MPI_RequestFatal error in MPI_Test:
> > > MPI_Test(152): MPI_Test(request=0x3b95388,
> > > flag=0x7fffb21504b4, status=0x7fffb2150420) failed
> > > MPI_Test(75).: Invalid MPI_Requestrank 3 in job 1
> > > compute-0-3.local_43455 caused collective abort of all ranks
> > > exit status of rank 3: killed by signal 9
> > > FYI this application was written to run on a Gentoo Box with
> > > mpich 1.2.5/7 and mpiexec (from OSC) v 0.75
> > > I am trying to port this to a new 64bit cluster, with all
> > > sorts of problems.
> > > Samir
> > > Sent: Monday, February 23, 2009 2:07 PM
> > > MPI_Request
> > > This can happen if you use an mpif.h or mpi.h from some other
> > > implementation. Remove any mpi*.h in the application
> > > directory and don't
> > > provide any paths to mpi*.h. mpic* will pick up the right file.
> > > Rajeev
> > Samir Khanal
> > > > Sent: Monday, February 23, 2009 11:35 AM
> > > > MPI_Request
> > > > Hi
> > > > [skhanal at comet ~]$ g++ -v
> > > > Using built-in specs.
> > > > Target: x86_64-redhat-linux
> > > > Configured with: ../configure --prefix=/usr
> > > > --mandir=/usr/share/man --infodir=/usr/share/info
> > > > --enable-shared --enable-threads=posix
> > > > --enable-checking=release --with-system-zlib
> > > > --enable-__cxa_atexit --disable-libunwind-exceptions
> > > > --enable-libgcj-multifile
> > > > --enable-languages=c,c++,objc,obj-c++,java,fortran,ada
> > > > --enable-java-awt=gtk --disable-dssi --enable-plugin
> > > > --with-java-home=/usr/lib/jvm/java-1.4.2-gcj-1.4.2.0/jre
> > > > --with-cpu=generic --host=x86_64-redhat-linux
> > > > Thread model: posix
> > > > gcc version 4.1.2 20071124 (Red Hat 4.1.2-42)
> > > > [skhanal at comet ~]$ which mpicxx
> > > > ~/mpich2/bin/mpicxx
> > > > [skhanal at comet ~]$ which mpicc
> > > > ~/mpich2/bin/mpicc
> > > > [skhanal at comet ~]$ which mpiexec
> > > > ~/mpich2/bin/mpiexec
> > > > i have installed all on my home directory
> > > > when i compile i do
> > > > [skhanal at comet ~]$ /home/skhanal/mpich2/bin/mpicxx -L
> > > > /home/skhanal/bgtw/lib -lbgtw bgtwRingTest.cpp -o Ring
> > > > [skhanal at comet ~]$ ./Ring
> > > > MPI_Test(152): MPI_Test(request=0x16ae9388,
> > > > flag=0x7fff7a7599c4, status=0x7fff7a759930) failed
> > > > the library needs a mpi.h file to include, i gave
> > > > /home/skhanal/mpich2/include/mpi.h as an absolute path.
> > > > any clues?
> > > > Thanks
> > > > Samir
> > > > [mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Gus Correa
> > > > [gus at ldeo.columbia.edu]
> > > > Sent: Monday, February 23, 2009 12:32 PM
> > > > To: Mpich Discuss
> > > > MPI_Request
> > > > Hi Samir, list
> > > > I am wondering if the mpicxx and mpiexec you are using
> > > > belong to the same MPICH2 build (considering the problems you
> > > > reported before).
> > > > What is the output of "which mpicxx" and "which mpiexec"?
> > > > You may want to use full path names to mpicxx and mpiexec,
> > > > as Anthony Chan recommended in another email.
> > > > Problems with PATH and multiple versions and builds of MPI
> > > > that hang around all Linux computers
> > > > has been an endless source of frustration for many.
> > > > I myself prefer to use full path names when I am testing
> > > > MPI programs, to avoid any confusion and distress.
> > > > I hope this helps,
> > > > Gus Correa
> > > > Gustavo Correa
> > > > Lamont-Doherty Earth Observatory - Columbia University
> > > > Palisades, NY, 10964-8000 - USA
> > > > Samir Khanal wrote:
> > > > > Hi All
> > > > > I tried and did the following.
> > > > > [skhanal at comet ~]$ mpicxx -L /home/skhanal/bgtw/lib -lbgtw
> > > > > [skhanal at comet ~]$ mpiexec -n 4 ./Ring
> > > > > MPI_Test(152): MPI_Test(request=0x1f820388,
> > > > flag=0x7fffb8236134, status=0x7fffb82360a0) failed
> > > > > MPI_Test(75).: Invalid MPI_Requestrank 0 in job 35
> > > > comet.cs.bgsu.edu_35155 caused collective abort of all ranks
> > > > > exit status of rank 0: killed by signal 9
> > > > > What does this mean?
> > > > > Samir
> > > > > Ps: I am using mpich2 1.0.8
