[mpich-discuss] Fatal error in MPI_Test: Invalid MPI_Request
    Rajeev Thakur
    thakur at mcs.anl.gov
    Thu Feb 26 15:31:13 CST 2009
In general, remove all your copies of mpi.h from the application directory.
Let mpicc/mpif90 pick up the right mpi.h from its installation.
Rajeev
> -----Original Message-----
> From: mpich-discuss-bounces at mcs.anl.gov
> [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Samir Khanal
> Sent: Thursday, February 26, 2009 2:32 PM
> To: mpich-discuss at mcs.anl.gov
> Subject: Re: [mpich-discuss] Fatal error in MPI_Test: Invalid
> MPI_Request
> Hi Rajeev, list
> I am using the mpi.h from mpich2,
> the program compiled very well (i am building a library) in a
> X86 box and ran without error with mpiexec 0.82 and mpich 1.2.7
> I am trying to replicate the same at a x86_64 system with
> mpich 1.2.7 and mpiexec 0.83
> and mpich2 and its mpiexec.
> The library compiles, but i get the same error as my previous email.
> with mpich 1.2.7 / mpiexec 0.82 i get P4 error sigx 15 error
> (which Gus suggested was due to old library and i compiled
> mpich2 with nemesis channel..)
> with mpich2  / and its mpiexec shows  the following as a job output.
> This job is running on following Processors
> compute-0-3 compute-0-3 compute-0-3 compute-0-3 compute-0-2
> compute-0-2 compute-0-2 compute-0-2
> Fatal error in MPI_Test: Invalid MPI_Request, error stack:
> MPI_Test(152): MPI_Test(request=0x7098388,
> flag=0x7fffdda3ea34, status=0x7fffdda3e9a0) failed
> MPI_Test(75).: Invalid MPI_RequestFatal error in MPI_Test:
> MPI_Test(152): MPI_Test(request=0x3b95388,
> flag=0x7fffb21504b4, status=0x7fffb2150420) failed
> MPI_Test(75).: Invalid MPI_Requestrank 3 in job 1
> compute-0-3.local_43455   caused collective abort of all ranks
>   exit status of rank 3: killed by signal 9
> FYI this application was written to run on a Gentoo Box with
> mpich 1.2.5/7  and mpiexec (from OSC) v 0.75
> I am trying to port this to a new 64bit cluster, with all
> sorts of problems.
> Samir
> [mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Rajeev
> Thakur [thakur at mcs.anl.gov]
> Sent: Monday, February 23, 2009 2:07 PM
> MPI_Request
> This can happen if you use an mpif.h or mpi.h from some other
> implementation. Remove any mpi*.h in the application
> directory and don't
> provide any paths to mpi*.h. mpic* will pick up the right file.
> Rajeev
> > Sent: Monday, February 23, 2009 11:35 AM
> > MPI_Request
> > Hi
> > [skhanal at comet ~]$ g++ -v
> > Using built-in specs.
> > Target: x86_64-redhat-linux
> > Configured with: ../configure --prefix=/usr
> > --mandir=/usr/share/man --infodir=/usr/share/info
> > --enable-shared --enable-threads=posix
> > --enable-checking=release --with-system-zlib
> > --enable-__cxa_atexit --disable-libunwind-exceptions
> > --enable-libgcj-multifile
> > --enable-languages=c,c++,objc,obj-c++,java,fortran,ada
> > --enable-java-awt=gtk --disable-dssi --enable-plugin
> > --with-java-home=/usr/lib/jvm/java-1.4.2-gcj-1.4.2.0/jre
> > --with-cpu=generic --host=x86_64-redhat-linux
> > Thread model: posix
> > gcc version 4.1.2 20071124 (Red Hat 4.1.2-42)
> > [skhanal at comet ~]$ which mpicxx
> > ~/mpich2/bin/mpicxx
> > [skhanal at comet ~]$ which mpicc
> > ~/mpich2/bin/mpicc
> > [skhanal at comet ~]$ which mpiexec
> > ~/mpich2/bin/mpiexec
> > i have installed all on my home directory
> > when i compile i do
> > [skhanal at comet ~]$ /home/skhanal/mpich2/bin/mpicxx -L
> > /home/skhanal/bgtw/lib -lbgtw bgtwRingTest.cpp -o Ring
> > [skhanal at comet ~]$ ./Ring
> > MPI_Test(152): MPI_Test(request=0x16ae9388,
> > flag=0x7fff7a7599c4, status=0x7fff7a759930) failed
> > the library needs a mpi.h file to include, i gave
> > /home/skhanal/mpich2/include/mpi.h as an absolute path.
> > any clues?
> > Thanks
> > Samir
> > [mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Gus Correa
> > [gus at ldeo.columbia.edu]
> > Sent: Monday, February 23, 2009 12:32 PM
> > To: Mpich Discuss
> > MPI_Request
> > Hi Samir, list
> > I am wondering if the mpicxx and mpiexec you are using
> > belong to the same MPICH2 build (considering the problems you
> > reported before).
> > What is the output of "which mpicxx" and "which mpiexec"?
> > You may want to use full path names to mpicxx and mpiexec,
> > as Anthony Chan recommended in another email.
> > Problems with PATH and multiple versions and builds of MPI
> > that hang around all Linux computers
> > has been an endless source of frustration for many.
> > I myself prefer to use full path names when I am testing
> > MPI programs, to avoid any confusion and distress.
> > I hope this helps,
> > Gus Correa
> > Gustavo Correa
> > Lamont-Doherty Earth Observatory - Columbia University
> > Palisades, NY, 10964-8000 - USA
> > Samir Khanal wrote:
> > > Hi All
> > > I tried and did the following.
> > > [skhanal at comet ~]$ mpicxx -L /home/skhanal/bgtw/lib -lbgtw
> > > [skhanal at comet ~]$ mpiexec -n 4 ./Ring
> > > MPI_Test(152): MPI_Test(request=0x1f820388,
> > flag=0x7fffb8236134, status=0x7fffb82360a0) failed
> > > MPI_Test(75).: Invalid MPI_Requestrank 0 in job 35
> > comet.cs.bgsu.edu_35155   caused collective abort of all ranks
> > >   exit status of rank 0: killed by signal 9
> > > What does this mean?
> > > Samir
> > > Ps: I am using mpich2 1.0.8
