[mpich-discuss] Error running app using MPICH - non-ASCII chars in	path
    Jayesh Krishna
    jayesh at mcs.anl.gov
    Tue Feb 24 11:27:06 CST 2009
 From the screenshot that you provided I can see that there are some
non-ASCII characters in the path to the program. Can you try re-launching
your job after moving your application (mpitestmpich.exe) to say c:\temp ?
Jayesh
  _____
[mailto:raymundo.santibanez at ae.ge.com]
Sent: Tuesday, February 24, 2009 9:53 AM
To: Jayesh Krishna
Subject: RE: [mpich2-maint] #420: Mpich2
Hi Jayesh:
I have another issue with other machine... I already reviewed the
firewall, I attached the machine error from command prompt and also the
error in the MPich configuration. Do you have any idea of what could cause
this error? I will appreciate your feedback. Thanks
By the way, No error showed during the instalation of MPich.
Thanks
Raymundo Santibáñez Santoscoy.
GE Infrastructure
Queretaro - UNISON
Analyst, Product Engineer,
T (52-442) 296-2566
D 8*879-2566
E  <mailto:raymundo.santibanez at ae.ge.com> raymundo.santibanez at ae.ge.com
<file:///C:/Documents%20and%20Settings/nhcuc1t/Application%20Data/Microsof
t/Signatures/www.ciat.com.mx> www.ciat.com.mx
Constituyentes 120 pte. 2o. piso
Col. Carrizal, 76030 Queretaro, Qro. Mexico.
Centro de Ingeniería Avanzada en Turbomáquinas S. de R.L. de C.V.
  _____
From: Jayesh Krishna [mailto:jayesh at mcs.anl.gov]
Sent: Monday, February 23, 2009 9:08 AM
To: Santibanez, Raymundo (GE Infra, Aviation)
Cc: mpich2-maint at mcs.anl.gov
  Great... Let us know if you need any help.
Jayesh
-----Original Message-----
[mailto:mpich2-bugs-bounces at mcs.anl.gov] On Behalf Of mpich2
Sent: Friday, February 20, 2009 6:24 PM
To: undisclosed-recipients:
Subject: Re: [mpich2-maint] #420: Mpich2
 Reporter:  "Santibanez, Raymundo (GE Infra, Aviation)"
<raymundo.santibanez at ae.ge.com>  |        Owner:  jayesh
     Type:  bug
|       Status:  assigned
 Priority:  major
|    Milestone:
Component:  mpich2
|   Resolution:
 Keywords:
Comment (by Santibanez, Raymundo (GE Infra, Aviation)):
 Hi Jayesh:
 It was really helpful your comments, It was the firewall, I will continue
working on this so if any other issue come up ...I will contact you.
 Thanks for your support.
 Kind Regards
 GE Infrastructure
 Queretaro - UNISON
 T (52-442) 296-2566
 D 8*879-2566
 E raymundo.santibanez at ae.ge.com <mailto:raymundo.santibanez at ae.ge.com>
 www.ciat.com.mx
 a/Microsoft/Signatures/www.ciat.com.mx>
 Sent: Wednesday, February 18, 2009 1:04 PM
 # Do you have a firewall (windows, third-party) running on this machine
(Turn  off any firewall running on the machine)?
 # Did you get any errors while installing MPICH2 ?
 # Can you try running a simple MPI program using MPICH2 on the machine ?
         MPICH2 installation provides you with a pre-compiled sample MPI
program,  cpi.exe, in the examples directory (<MPICH2-INSTALL-
DIR>\examples\cpi.exe). You  can run the MPI program with 2 processes on
the machine using the mpiexec  command (mpiexec -n 2 cpi.exe).
  Let us know the results.
 Jayesh
 From: mpich2-bugs-bounces at mcs.anl.gov [mailto:mpich2-bugs-
 Sent: Wednesday, February 18, 2009 12:55 PM
 Subject: [mpich2-maint] #420: Mpich2
 <raymundo.santibanez at ae.ge.com>  |        Type:  bug
    Status:  new
 |    Priority:  major
 Milestone:
 |   Component:  mpich2
  > Hi:
  > I request your help. I am trying to use Ansys distributed in Windows
32,  with  Ansys 11 and I have an error on 2 machines or computers. Could
you  please  help  me?
  > When I install the Mpich2 program seems that it was installed
succesfully,  but  when I see the configuration it already shows an error.
I attach some  images of  this error.
  > The enviromental variables that were added to the computer are:
  > 1.- In the Path variable name, it was added at the end the C:\Program
Files\MPICH2\bin  >  > 2.- It was added  > Variable name:  ANSYS_SYSDIR  >
Variable value:  \\*computer name\ansys inc\v110\ansys  >  > 3.-It was
added
  > Variable name:     ANSYS110_DIR
  > Variable value:     C:\program files\ansys inc\v110\ansys
  > 4.-It was added
  > Variable name:     ANSYSLIC_DIR
  > Variable value:     C:\Program Files\Ansys Inc\Shared Files\Licensing
  > I have perform this procedure in others 3 machines and they have no
issues.
 In  fact I already ran Ansys Distributed in those machines. But I can not
do  it  in  this 2 machines that shows the previous error.
  > I am not an expert on this so please try to answer in a manner so I
can  understand.
  > Thanks
  > I look forward for your answer, Please try to answer asap.
  > >  <<error.ppt>>
  GE Infrastructure
  Queretaro - UNISON
  T (52-442) 296-2566
  D 8*879-2566
  www.ciat.com.mx
 Ticket URL: <https://trac.mcs.anl.gov/projects/mpich2/ticket/420>
Ticket URL: <https://trac.mcs.anl.gov/projects/mpich2/ticket/420#comment:>
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20090224/9d1f7fe4/attachment-0001.htm>
