[mpich-discuss] Fatal error in MPI_Test: Invalid MPI_Request
Rajeev Thakur
thakur at mcs.anl.gov
Mon Feb 23 13:07:59 CST 2009
This can happen if you use an mpif.h or mpi.h from some other
implementation. Remove any mpi*.h in the application directory and don't
provide any paths to mpi*.h. mpic* will pick up the right file.
Rajeev
> -----Original Message-----
> From: mpich-discuss-bounces at mcs.anl.gov
> [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Samir Khanal
> Sent: Monday, February 23, 2009 11:35 AM
> To: mpich-discuss at mcs.anl.gov
> Subject: Re: [mpich-discuss] Fatal error in MPI_Test: Invalid
> MPI_Request
> Hi
> [skhanal at comet ~]$ g++ -v
> Using built-in specs.
> Target: x86_64-redhat-linux
> Configured with: ../configure --prefix=/usr
> --mandir=/usr/share/man --infodir=/usr/share/info
> --enable-shared --enable-threads=posix
> --enable-checking=release --with-system-zlib
> --enable-__cxa_atexit --disable-libunwind-exceptions
> --enable-libgcj-multifile
> --enable-languages=c,c++,objc,obj-c++,java,fortran,ada
> --enable-java-awt=gtk --disable-dssi --enable-plugin
> --with-java-home=/usr/lib/jvm/java-1.4.2-gcj-1.4.2.0/jre
> --with-cpu=generic --host=x86_64-redhat-linux
> Thread model: posix
> gcc version 4.1.2 20071124 (Red Hat 4.1.2-42)
> [skhanal at comet ~]$ which mpicxx
> ~/mpich2/bin/mpicxx
> [skhanal at comet ~]$ which mpicc
> ~/mpich2/bin/mpicc
> [skhanal at comet ~]$ which mpiexec
> ~/mpich2/bin/mpiexec
> i have installed all on my home directory
> when i compile i do
> [skhanal at comet ~]$ /home/skhanal/mpich2/bin/mpicxx -L
> /home/skhanal/bgtw/lib -lbgtw bgtwRingTest.cpp -o Ring
> [skhanal at comet ~]$ ./Ring
> Fatal error in MPI_Test: Invalid MPI_Request, error stack:
> MPI_Test(152): MPI_Test(request=0x16ae9388,
> flag=0x7fff7a7599c4, status=0x7fff7a759930) failed
> MPI_Test(75).: Invalid MPI_Request
> the library needs a mpi.h file to include, i gave
> /home/skhanal/mpich2/include/mpi.h as an absolute path.
> any clues?
> Thanks
> Samir
> [mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Gus Correa
> [gus at ldeo.columbia.edu]
> Sent: Monday, February 23, 2009 12:32 PM
> To: Mpich Discuss
> MPI_Request
> Hi Samir, list
> I am wondering if the mpicxx and mpiexec you are using
> belong to the same MPICH2 build (considering the problems you
> reported before).
> What is the output of "which mpicxx" and "which mpiexec"?
> You may want to use full path names to mpicxx and mpiexec,
> as Anthony Chan recommended in another email.
> Problems with PATH and multiple versions and builds of MPI
> that hang around all Linux computers
> has been an endless source of frustration for many.
> I myself prefer to use full path names when I am testing
> MPI programs, to avoid any confusion and distress.
> I hope this helps,
> Gus Correa
> Gustavo Correa
> Lamont-Doherty Earth Observatory - Columbia University
> Palisades, NY, 10964-8000 - USA
> Samir Khanal wrote:
> > Hi All
> > I tried and did the following.
> > [skhanal at comet ~]$ mpicxx -L /home/skhanal/bgtw/lib -lbgtw
> > [skhanal at comet ~]$ mpiexec -n 4 ./Ring
> > MPI_Test(152): MPI_Test(request=0x1f820388,
> flag=0x7fffb8236134, status=0x7fffb82360a0) failed
> > MPI_Test(75).: Invalid MPI_Requestrank 0 in job 35
> comet.cs.bgsu.edu_35155 caused collective abort of all ranks
> > exit status of rank 0: killed by signal 9
> > What does this mean?
> > Samir
> > Ps: I am using mpich2 1.0.8
