[mpich-discuss] Running mpiexec on WIndows Computers
    Jayesh Krishna
    jayesh at mcs.anl.gov
    Fri Feb 20 14:39:35 CST 2009
 Please run the command below and provide us with the output
(system_info_machines1_2.log),
      mpiexec -hosts 2 IPADDRESS_OF_MACHINE1 IPADDRESS_OF_MACHINE2
systeminfo  > system_info_machines1_2.log
 Instead of trying out cpi.exe try compiling and running the following
helloworld program,
################# hello world #####################
#include <stdio.h>
#include "mpi.h"
int main(int argc, char *argv[])
     int rank = -1;
     MPI_Init(&argc, &argv);
     MPI_Comm_rank(MPI_COMM_WORLD, &rank);
     printf("[%d] Hello world\n", rank);
     MPI_Finalize();
 Compile the program above, copy it to c:\temp, and run it as follows,
c:\temp\hello_world.exe
 Let us know the results.
Jayesh
  _____
Sent: Thursday, February 19, 2009 4:24 PM
To: 'Jayesh Krishna'
Cc: mpich-discuss at mcs.anl.gov
Subject: RE: [mpich-discuss] Running mpiexec on WIndows Computers
I copied cpi to c:\temp, but still the same problem.
-Zhong
From: Jayesh Krishna [mailto:jayesh at mcs.anl.gov]
Sent: Thursday, February 19, 2009 2:08 PM
To: 'Zhong Wu'
 A quick note -- Copy cpi.exe to a non-user specific directory like
c:\temp (Move cpi.exe from "c:\Users\zhong.wu\Documents" to "c:\temp") on
both the machines and try running your MPI job.
-jayesh
-----Original Message-----
Sent: Thursday, February 19, 2009 3:49 PM
I have tried hostname and ipaddress both.
I attached the spmd and mpiexec logs from one of my computer.
Thanks.
-Zhong
Sent: Thursday, February 19, 2009 1:38 PM
To: 'Zhong Wu'
Please provide as much information in your email as possible. Did you try
using machine file with ipaddresses (instead of hostnames)?
-jayesh
Sent: Thursday, February 19, 2009 3:25 PM
The machine file didn't work.
-Zhong
Sent: Thursday, February 19, 2009 9:43 AM
To: 'Zhong Wu'
>> But from one remote I have to use ipaddress to start remote
process...
 So did you try running cpi by specifying ipaddresses ? Also let us know
whether the "-machinefile" option works for you (make sure that you
specify ipaddresses of the machines in your machine file).
Jayesh
Sent: Thursday, February 19, 2009 11:27 AM
I can run cpi on both remote computers with -hosts 1, but not two
computers at same time. But from one remote I have to use ipaddress to
start remote process.
I turned off firewall completely, still the same problem.
I found the cpi.exe processes are already started in both computers
(remote and local).
-Zhong
Sent: Thursday, February 19, 2009 8:57 AM
To: 'Zhong Wu'
1) Did you try executing cpi.exe remotely from both the machines
(mpiexec -hosts 1 remotecomputer... from both the machines)?
2) Do you have any windows firewall or third party firewall running on
your machine (turn it off if its running)?
3) Try specifying the ipaddresses of machines (Due to DNS config issues
one host may not be able to resolve the other hosts name) instead of
hostnames.
Jayesh
[mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Zhong Wu
Sent: Thursday, February 19, 2009 10:42 AM
Subject: Re: [mpich-discuss] Running mpiexec on WIndows Computers
Yes. I am using the latest mpich2 version 1.08. one of my computer is
running vista and the other one is windows server 2008. I will try
machinefile.
-Zhong
[mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Jayesh Krishna
Sent: Thursday, February 19, 2009 7:22 AM
To: 'Sole Eko'
 Did you recently upgrade to the latest version of MPICH2 (1.0.8)?
(PS: I just verified that I can run cpi across two Win XP machines using
a machinefile or the "-hosts" option.)
Jayesh
[mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Sole Eko
Sent: Thursday, February 19, 2009 3:46 AM
Hi Zhong,
same problem I'm facing..
is this some bug in last release of MPICH2..?
Sole
On Thu, Feb 19, 2009 at 8:37 AM, Zhong Wu <zhong.wu at 3i-systems.com>
wrote:
I am setting up mpich2 on two windows computers. I created same
user/password on both computers and use mpiexec -register to register
user/password. I could run the sample program cpi.exe in local and
remote computer through
mpiexec -hosts 1 localcomputer 2 c:\samples\cpi.exe
mpiexec -hosts 1 remotecomputer 2 c:\samples\cpi.exe
but I cannot run the sample on both computer at once
mpiexec -hosts 2 localcomputer 2 remotecomputer 2 c:\samples\cpi.exe
mpiexec will hang after the interval.
-Zhong
No virus found in this incoming message.
Checked by AVG - www.avg.com
Version: 8.0.237 / Virus Database: 270.11.0/1959 - Release Date:
02/18/09 20:55:00
02/18/09 20:55:00
02/19/09 10:48:00
Version: 8.0.237 / Virus Database: 270.11.0/1959 - Release Date: 02/19/09
10:48:00
10:48:00
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20090220/6b7dcfc7/attachment.htm>
