[mpich-discuss] mpiexec kills the remote login shell
Yu-Cheng Chou cycchou at ucdavis.edu
Wed Feb 4 13:01:31 CST 2009
Firstly, the previously attached mpiexec verbose output is a wrong one.
I've attached the correct one to this email.
Secondly, I want to point out that as long as mpiexec is initiated
from Korebot to run a program, no matter it's a MPI or non-MPI
program, no matter the program can be found or not, as soon as mpiexec
is finished, the ssh connection to Korebot will be gone.
Thank you
> Hi,
>   The mpiexec output shows the following error when running hellow,
> Unable to exec 'hello' on korebot
> Error 2 - No such file or directory
>   Please provide the debug output of smpd (smpd -d 2>&1 |
> tee smpd.out) along with mpiexec (mpiexec -verbose -n 2 ./hellow 2>&1 |
> tee mpiexec.out).
> #  Can you run simple C programs (without using mpiexec) on Korbet ?
> #  Is the ssh connection aborted when you run non-MPI programs (mpiexec -n 2
> hostname) ?
> #  Can you send us your ".smpd" config file ?
> #  Did you modify the MPICH2 code to run on Korbet (Please send us your
> configure command & any env settings set to configure/make MPICH2)?
> Regards,
> Jayesh
> ________________________________
> From: mpich-discuss-bounces at mcs.anl.gov
> [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Jayesh Krishna
> Sent: Wednesday, February 04, 2009 8:41 AM
> To: 'Yu-Cheng Chou'
> Cc: mpich-discuss at mcs.anl.gov
> Subject: Re: [mpich-discuss] mpiexec kills the remote login shell
>  Hi,
>   I will take a look at the debug logs and get back to you. Meanwhile, can
> you run simple C programs without using mpiexec on Korbet ?
>   MPICH2 currently does not support heterogeneous systems (So you won't be
> able to run your MPI job across ARM & other architectures).
> Regards,
> Jayesh
> -----Original Message-----
> From: Yu-Cheng Chou [mailto:cycchou at ucdavis.edu]
> Sent: Tuesday, February 03, 2009 7:52 PM
> To: Jayesh Krishna
>> # Can you run non-MPI programs using mpiexec (mpiexec -n 2 hostname) ?
> Yes.
>> # Can you compile and run the hello world program (examples/hellow.c)
>> provided with MPICH2 (mpiexec -n 2 ./hellow)?
> Yes.
>> # How did you start smpd (the command used to start smpd) ? How did
>> you run your MPI job (the command used to run your job)?
> I have a ".smpd" file containing one line of information, which is
> "phrase=123".
> Thus, I started smpd using "smpd -s".
> Then I used "mpiexec -n 1 hellow" to run hellow on Korebot.
>> # How did you find that mpiexec kills the sshd process (We typically
>> ssh to unix machines and run mpiexec without any problems) ?
> I logged in Korebot with two terminals.
> >From #1 terminal, I checked all the processes running on Korebot.
> >From #2 terminal, I started smpd and run hellow using the commands
> mentioned above.
> After hellow was finished, the connection to Korebot via #2 terminal was
> closed.
> >From #1 terminal, I knew that the sshd process associated with #2 terminal
> was gone.
>>  Can you run smpd/mpiexec in debug mode and provide us with the
>> outputs (smpd -d / mpiexec -n 2 -verbose hostname) ?
> The first attached text file is the output from running hellow in mpiexec's
> verbose mode.
> There is another issue.
> This time, I used two machines. One is Korebot as mentioned above, and the
> other is a laptop running Ubuntu Linux OS.
> I started smpd with the same ".smpd" file and command as mentioned above
> both on Korebot and the lap top.
> There is a machine file called "hostfile" on Korebot. The file contains the
> following information about the name of the two machines.
> korebot
> shrimp
> Then from Korebot, I ran cpi using the following command.
> mpiexec -machinefile ./hostfile -verbose -n 2 cpi
> But the value of pi is a huge number. I think it is related to "double type
> variables" being transferred between processes running on an ARM-based Linux
> and a general Linux machines.
> The second attached text file is the output from running cpi in mpiexec's
> verbose mode.
>> I am cross-compiling mpich2-1.0.8 with smpd for Khepera III mobile robot.
>> This mobile robot has a Korebot board which is an ARM-based computer
>> with a Linux operating system.
>> The cross-compilation was fine.
>> Firstly, I logged in to Korebot through ssh.
>> Secondly, I started smpd.
>> Thirdly, I ran mpiexec to execute an MPI program (cpi) that comes with
>> the package.
>> The result was correct, but when mpiexec was finished, the ssh
>> connection to the Korebot was closed.
>> I found that mpiexec kills the sshd process through which I was
>> remotely connected to Korebot.
>> I've been looking for the cause, but still have not found any clues.
>> Could you give me any ideas to solve this problem?
>> Thank you,
>> Yu-Cheng
~ # mpiexec -n 1 -verbose hellow
..\smpd_get_full_path_name
...\smpd_search_path
.../smpd_search_path
../smpd_get_full_path_name
..handling executable:
hellow
..\smpd_get_next_host
...\smpd_get_next_hostname
.../smpd_get_next_hostname
...\smpd_get_host_id
.../smpd_get_host_id
..\smpd_create_cliques
...\next_launch_node
.../next_launch_node
../smpd_create_cliques
..\smpd_fix_up_host_tree
../smpd_fix_up_host_tree
./mp_parse_command_args
.host tree:
. host: korebot, parent: 0, id: 1
.launch nodes:
. iproc: 0, id: 1, exe: hellow
.\smpd_get_smpd_data
..\smpd_hide_string_arg
...\first_token
.../first_token
...\compare_token
.../compare_token
...\next_token
....\first_token
..../first_token
....\first_token
..../first_token
.../next_token
../smpd_hide_string_arg
..\smpd_get_smpd_data_from_environment
../smpd_get_smpd_data_from_environment
..\smpd_parse_smpd_file
...\smpd_open_smpd_file
.../smpd_open_smpd_file
...\str_replace
.../str_replace
../smpd_parse_smpd_file
...\first_token
.../first_token
...\compare_token
.../compare_token
...\next_token
....\first_token
..../first_token
....\first_token
..../first_token
.../next_token
.\smpd_create_context
..\smpd_init_context
...\smpd_init_command
.../smpd_init_command
../smpd_init_context
./smpd_create_context
.\smpd_enter_at_state
..sock_waiting for the next event.
..SOCK_OP_CONNECT
..\smpd_handle_op_connect
...connect succeeded, posting read of the challenge string
../smpd_handle_op_connect
..SOCK_OP_READ
..\smpd_handle_op_read
...\smpd_state_reading_challenge_string
....read challenge string: '1.0.8 1471905457'
....\smpd_verify_version
..../smpd_verify_version
....\smpd_hash
..../smpd_hash
.../smpd_state_reading_challenge_string
../smpd_handle_op_read
..SOCK_OP_WRITE
..\smpd_handle_op_write
...\smpd_state_writing_challenge_response
....wrote challenge response: '43f316afe9828d3898d700bff9134ae4'
.../smpd_state_writing_challenge_response
../smpd_handle_op_write
..SOCK_OP_READ
...\smpd_state_reading_connect_result
....read connect result: 'SUCCESS'
.../smpd_state_reading_connect_result
..SOCK_OP_WRITE
...\smpd_state_writing_process_session_request
....wrote process session request: 'process'
.../smpd_state_writing_process_session_request
..SOCK_OP_READ
...\smpd_state_reading_cred_request
....read cred request: 'nocredentials'
.../smpd_state_reading_cred_request
..SOCK_OP_READ
...\smpd_state_reading_reconnect_request
....read re-connect request: '-1'
....\smpd_generate_session_header
.....session header: (id=1 parent=0 level=0)
..../smpd_generate_session_header
.../smpd_state_reading_reconnect_request
..SOCK_OP_WRITE
...\smpd_state_writing_session_header
....wrote session header: 'id=1 parent=0 level=0'
....\smpd_post_read_command
.....posting a read for a command header on the left context, sock 16777216
..../smpd_post_read_command
....\smpd_create_command
.....\smpd_init_command
...../smpd_init_command
..../smpd_create_command
....\smpd_post_write_command
.....\smpd_package_command
...../smpd_package_command
.....smpd_post_write_command on the left context sock 16777216: 47 bytes for command: "cmd=start_dbs src=0 dest=1 tag=0 "
..../smpd_post_write_command
.../smpd_state_writing_session_header
..SOCK_OP_WRITE
...\smpd_state_writing_cmd
....wrote command
....command written to left: "cmd=start_dbs src=0 dest=1 tag=0 "
....moving 'start_dbs' command to the wait_list.
.../smpd_state_writing_cmd
..SOCK_OP_READ
...\smpd_state_reading_cmd_header
....read command header
....command header read, posting read for data: 160 bytes
.../smpd_state_reading_cmd_header
..SOCK_OP_READ
....read command
....\smpd_parse_command
..../smpd_parse_command
....read command: "cmd=result src=1 dest=0 tag=0 cmd_tag=0 cmd_orig=start_dbs kvs_name=29ACA79B394768F819EB9C038F24EDD domain_name=5FB3CD031BDC64F194A6F3874AC78C5 result=SUCCESS "
....\smpd_handle_command
.....handling command:
..... src  = 1
..... dest = 0
..... cmd  = result
..... tag  = 0
..... ctx  = left
..... len  = 160
..... str  = cmd=result src=1 dest=0 tag=0 cmd_tag=0 cmd_orig=start_dbs kvs_name=29ACA79B394768F819EB9C038F24EDD domain_name=5FB3CD031BDC64F194A6F3874AC78C5 result=SUCCESS
.....\smpd_command_destination
......0 -> 0 : returning NULL context
...../smpd_command_destination
.....\smpd_handle_result
......start_dbs succeeded, kvs_name: '29ACA79B394768F819EB9C038F24EDD', domain_name: '5FB3CD031BDC64F194A6F3874AC78C5'
......\smpd_launch_processes
.......creating a process group of size 1 on node 0 called 29ACA79B394768F819EB9C038F24EDD
.......\create_process_group
......./create_process_group
.......launching the processes.
.......\smpd_create_command
........\smpd_init_command
......../smpd_init_command
......./smpd_create_command
.......\smpd_add_command_arg
......./smpd_add_command_arg
.......\smpd_add_command_int_arg
......./smpd_add_command_int_arg
.......\smpd_post_write_command
........\smpd_package_command
......../smpd_package_command
........smpd_post_write_command on the left context sock 16777216: 157 bytes for command: "cmd=launch src=0 dest=1 tag=1 c=hellow s=0 a=0 d=/root p=/bin q=0 i=0 n=1 k=29ACA79B394768F819EB9C038F24EDD kd=5FB3CD031BDC64F194A6F3874AC78C5 "
......./smpd_post_write_command
....../smpd_launch_processes
......\smpd_free_command
....../smpd_free_command
...../smpd_handle_result
..../smpd_handle_command
..SOCK_OP_WRITE
....wrote command
....command written to left: "cmd=launch src=0 dest=1 tag=1 c=hellow s=0 a=0 d=/root p=/bin q=0 i=0 n=1 k=29ACA79B394768F819EB9C038F24EDD kd=5FB3CD031BDC64F194A6F3874AC78C5 "
....moving 'launch' command to the wait_list.
..SOCK_OP_READ
....command header read, posting read for data: 129 bytes
..SOCK_OP_READ
....read command
....read command: "cmd=result src=1 dest=0 tag=1 cmd_tag=1 cmd_orig=launch result=SUCCESS pg_id=29ACA79B394768F819EB9C038F24EDD pg_rank=0 pg_ctx=0 "
..... src  = 1
..... dest = 0
..... cmd  = result
..... tag  = 1
..... ctx  = left
..... len  = 129
..... str  = cmd=result src=1 dest=0 tag=1 cmd_tag=1 cmd_orig=launch result=SUCCESS pg_id=29ACA79B394768F819EB9C038F24EDD pg_rank=0 pg_ctx=0
......successfully launched: 'cmd=launch src=0 dest=1 tag=1 c=hellow s=0 a=0 d=/root p=/bin q=0 i=0 n=1 k=29ACA79B394768F819EB9C038F24EDD kd=5FB3CD031BDC64F194A6F3874AC78C5 '
......root process launched, starting stdin redirection.
......\smpd_create_context
.......\smpd_init_context
......./smpd_init_context
....../smpd_create_context
..SOCK_OP_READ
....command header read, posting read for data: 100 bytes
..SOCK_OP_READ
....read command
....read command: "cmd=init src=1 dest=0 tag=0 ctx_key=0 name=29ACA79B394768F819EB9C038F24EDD key=0 value=1 node_id=1 "
..... src  = 1
..... dest = 0
..... cmd  = init
..... tag  = 0
..... ctx  = left
..... len  = 100
..... str  = cmd=init src=1 dest=0 tag=0 ctx_key=0 name=29ACA79B394768F819EB9C038F24EDD key=0 value=1 node_id=1
.....\smpd_handle_init_command
......\get_name_key_value
....../get_name_key_value
......init: 0:1:29ACA79B394768F819EB9C038F24EDD
......sending reply to init command 'cmd=init src=1 dest=0 tag=0 ctx_key=0 name=29ACA79B394768F819EB9C038F24EDD key=0 value=1 node_id=1 '.
......sending result command to left context: "cmd=result src=0 dest=1 tag=2 cmd_tag=0 ctx_key=0 result=SUCCESS "
.......smpd_post_write_command on the left context sock 16777216: 79 bytes for command: "cmd=result src=0 dest=1 tag=2 cmd_tag=0 ctx_key=0 result=SUCCESS "
...../smpd_handle_init_command
..SOCK_OP_WRITE
....wrote command
....command written to left: "cmd=result src=0 dest=1 tag=2 cmd_tag=0 ctx_key=0 result=SUCCESS "
..SOCK_OP_READ
....command header read, posting read for data: 96 bytes
..SOCK_OP_READ
....read command
....read command: "cmd=finalize src=1 dest=0 tag=2 ctx_key=0 name=29ACA79B394768F819EB9C038F24EDD key=0 node_id=1 "
..... src  = 1
..... dest = 0
..... cmd  = finalize
..... tag  = 2
..... ctx  = left
..... len  = 96
..... str  = cmd=finalize src=1 dest=0 tag=2 ctx_key=0 name=29ACA79B394768F819EB9C038F24EDD key=0 node_id=1
.....\smpd_handle_finalize_command
......finalize: 0:29ACA79B394768F819EB9C038F24EDD
......sending reply to finalize command 'cmd=finalize src=1 dest=0 tag=2 ctx_key=0 name=29ACA79B394768F819EB9C038F24EDD key=0 node_id=1 '.
......sending result command to left context: "cmd=result src=0 dest=1 tag=3 cmd_tag=2 ctx_key=0 result=SUCCESS "
.......smpd_post_write_command on the left context sock 16777216: 79 bytes for command: "cmd=result src=0 dest=1 tag=3 cmd_tag=2 ctx_key=0 result=SUCCESS "
...../smpd_handle_finalize_command
..SOCK_OP_WRITE
....wrote command
....command written to left: "cmd=result src=0 dest=1 tag=3 cmd_tag=2 ctx_key=0 result=SUCCESS "
..SOCK_OP_READ
....command header read, posting read for data: 116 bytes
..SOCK_OP_READ
....read command
....read command: "cmd=stdout src=1 dest=0 tag=3 rank=0 first=1 data=48656C6C6F20776F726C642066726F6D2070726F636573732030206F6620310A "
..... src  = 1
..... dest = 0
..... cmd  = stdout
..... tag  = 3
..... ctx  = left
..... len  = 116
..... str  = cmd=stdout src=1 dest=0 tag=3 rank=0 first=1 data=48656C6C6F20776F726C642066726F6D2070726F636573732030206F6620310A
.....\smpd_handle_stdout_command
......\write_to_stdout
Hello world from process 0 of 1
....../write_to_stdout
...../smpd_handle_stdout_command
..SOCK_OP_READ
....command header read, posting read for data: 79 bytes
..SOCK_OP_READ
....read command
....read command: "cmd=exit src=1 dest=0 tag=4 rank=0 code=0 kvs=29ACA79B394768F819EB9C038F24EDD "
..... src  = 1
..... dest = 0
..... cmd  = exit
..... tag  = 4
..... ctx  = left
..... len  = 79
..... str  = cmd=exit src=1 dest=0 tag=4 rank=0 code=0 kvs=29ACA79B394768F819EB9C038F24EDD
.....\smpd_handle_exit_command
......saving exit code: rank 0, exitcode 0, pg <29ACA79B394768F819EB9C038F24EDD>
......last process exited, returning SMPD_EXIT.
...../smpd_handle_exit_command
.....smpd_post_write_command on the left context sock 16777216: 43 bytes for command: "cmd=close src=0 dest=1 tag=4 "
..SOCK_OP_WRITE
....wrote command
....command written to left: "cmd=close src=0 dest=1 tag=4 "
..SOCK_OP_READ
....command header read, posting read for data: 31 bytes
..SOCK_OP_READ
....read command
....read command: "cmd=closed src=1 dest=0 tag=5 "
..... src  = 1
..... dest = 0
..... cmd  = closed
..... tag  = 5
..... ctx  = left
..... len  = 31
..... str  = cmd=closed src=1 dest=0 tag=5
.....\smpd_handle_closed_command
......closed command received from left child, closing sock.
......MPIDU_Sock_post_close(16777216)
......received a closed at node with no parent context, assuming root, returning SMPD_EXITING.
...../smpd_handle_closed_command
....not posting read for another command because SMPD_EXITING returned
..SOCK_OP_CLOSE
..\smpd_handle_op_close
...\smpd_get_state_string
.../smpd_get_state_string
...op_close received - SMPD_EXITING state.
...\smpd_free_context
....freeing left context.
.../smpd_free_context
../smpd_handle_op_close
./smpd_enter_at_state
/main
\smpd_exit
.\smpd_kill_all_processes
./smpd_kill_all_processes
.\smpd_dbs_finalize
./smpd_dbs_finalize
~ # Connection to korebot closed.
