[mpich-discuss] Hi
    Jayesh Krishna
    jayesh at mcs.anl.gov
    Wed Feb  4 12:29:03 CST 2009
 The error message says it all,
cannot open input file 'mpi.lib'
 Make sure that you have specified the path to mpi.lib correctly.
(PS: You can ask your system administrator to help you with the Visual
Studio project settings)
Jayesh
  _____
From: kuldeep matarasi [mailto:kuldeep22011984 at yahoo.com]
Sent: Wednesday, February 04, 2009 12:25 PM
To: jayesh at mcs.anl.gov
Subject: RE: Hi
Thank You so much Jayesh, i tried the steps that you mentioned but this
time it is giving a different error message.Could you please let me know
what i could do?Thank You
Kuldeep M
1>------ Build started: Project: hellpmic, Configuration: Debug Win32
1>Linking...
1>LINK : fatal error LNK1181: cannot open input file 'mpi.lib'
1>Build log was saved at "file://c:\Documents and Settings\kmatharasi\My
Documents\Visual Studio
2005\Projects\hellpmi.c\hellpmi.c\Debug\BuildLog.htm"
1>hellpmi.c - 1 error(s), 0 warning(s)
========== Build: 0 succeeded, 1 failed, 0 up-to-date, 0 skipped
--- On Wed, 2/4/09, Jayesh Krishna <jayesh at mcs.anl.gov> wrote:
Subject: RE: Hi
To: kuldeep22011984 at yahoo.com
Cc: mpich-discuss at mcs.anl.gov
Date: Wednesday, February 4, 2009, 9:42 PM
 The linker error indicates that you have not specified the MPICH2
libraries as "Additional dependencies" for the linker.
 Specify the path of MPICH2 libraries (the default path is "c:\program
files\mpich2\lib") in "Additional library directories" (Project properties
--> Configuration properties --> Linker --> Additional library
directories). Specify the MPICH2 libraries (mpi.lib) as "Additional
dependencies" (Project properties --> Configuration properties --> Linker
--> Input --> Additional dependencies).
 You can find this information in the windows developer's guide (available
at
http://www.mcs.anl.gov/research/projects/mpich2/documentation/index.php?s=
docs). You can also refer to the example project files installed with
MPICH2 (examples\examples.sln).
 Let us know if you still have problems.
Jayesh
  _____
Sent: Wednesday, February 04, 2009 9:57 AM
Subject: Hi
Hello,
 I'm a newbie in MPI ,i have a problem when trying to execute a "hello
world" application. I'm using
Microsoft Visual C++ 2005 on a Windows Machine and I have installed mpich2
on windows xp
I will be grateful to you if you could please help me fix.Thanks for your
time.
Regards
Kuldeep M
My code is:
#include "mpi.h"
#include <stdio.h>
int main( int argc, char *argv[] )
    MPI_Init( &argc, &argv );
    printf( "Hello, world!\n" );
    MPI_Finalize();
    return 0;
1>------ Build started: Project: mpihello.c, Configuration: Debug Win32
1>Linking...
1>mpihello.obj : error LNK2019: unresolved external symbol _MPI_Finalize
referenced in function _main
1>mpihello.obj : error LNK2019: unresolved external symbol _MPI_Init
referenced
 in function _main
1>C:\Documents and
 Documents\Visual Studio 2005\Projects\mpihello.c\Debug\mpihello.c.exe :
fatal error LNK1120: 2 unresolved externals
2005\Projects\mpihello.c\mpihello.c\Debug\BuildLog.htm"
1>mpihello.c - 3 error(s), 0 warning(s)
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20090204/083fec57/attachment.htm>
