[mpich-discuss] building 64-bit MPICH2 on AIX
    Robert Yelle
    ryelle at uoregon.edu
    Tue Feb  3 18:15:54 CST 2009
Hello Dave,
I just typed "make" (GNU Make 3.80), but in response to your comment I
just tried "make -j 1", and it resulted in the same error.
Robert
Dave Goodell wrote:
> Hi Robert,
> Are you building with "make -j N"?  These look like errors that would
> be produced from a parallel make.  The mpich2 build process doesn't
> support parallel make at this time.
> -Dave
> On Feb 3, 2009, at 2:55 PM, Robert Yelle wrote:
>> Hello,
>> Has anybody tried to build 64-bit versions of MPICH2 on an AIX
>> platform?  What arguments should one use?  I tried to build a 64-bit
>> version of MPICH2 (version 1.0.8) using the following arguments:
>> > ./configure
>> --prefix=/usr/local/packages/mpich2/1.0.8_ibm-9.0-11.1_64
>> OBJECT_MODE=64 C
>> C=/usr/vacpp/bin/xlc CXX=/usr/vacpp/bin/xlc++ FC=/bin/xlf
>> F77=/bin/xlf F90=/bin/xlf90 CFLA
>> GS=-q64 FFLAGS=-q64 F90FLAGS=-q64 MPICH2LIB_CFLAGS=-q64
>> MPICH2LIB_FFLAGS=-q64 MPICH2LIB_CX
>> XFLAGS=-q64 MPICH2LIB_F90FLAGS=-q64
>> Configure works fine, but "make" exits with the following error:
>> make[3]: Leaving directory
>> `/mnt/netapp/packages/src/mpich2-1.0.8/src/binding/cxx'
>> make[2]: Leaving directory
>> `/mnt/netapp/packages/src/mpich2-1.0.8/src/binding'
>> make[2]: Entering directory
>> `/mnt/netapp/packages/src/mpich2-1.0.8/src/env'
>> /usr/vacpp/bin/xlc -DHAVE_CONFIG_H -I. -I. -I../include -q64 -O2 -q64
>> -I/usr/local/packages/src/mpich2-1.0.8/src/mpid/ch3/include
>> -I/usr/local/packages/src/mpich2-1.0.8/src/mpid/common/datatype
>> -I/usr/local/packages/src/mpich2-1.0.8/src/mpid/common/locks
>> -I/usr/local/packages/src/mpich2-1.0.8/src/mpid/ch3/channels/sock/include
>> -I/usr/local/packages/src/mpich2-1.0.8/src/mpid/common/sock
>> -I/usr/local/packages/src/mpich2-1.0.8/src/mpid/common/sock/poll
>> -I/usr/local/packages/src/mpich2-1.0.8/src/mpid/common/sock/poll -c
>> mpich2version.c
>> /usr/vacpp/bin/xlc -q64 -O2 -q64  -o mpich2version mpich2version.o  \
>> ../../lib/libmpich.a -lpthread          ld: 0711-204 SEVERE ERROR:
>> Archive file ../../lib/libmpich.a cannot be processed.
>>       The number of archive members (0), specified in the archive member
>>       table, is less than or equal to 0 or is not consistent with the
>> length
>>       of the member table.
>> make[2]: *** [mpich2version] Error 12
>> make[1]: *** [all-redirect] Error 2
>> make[1]: Leaving directory `/mnt/netapp/packages/src/mpich2-1.0.8/src'
>> make: *** [all-redirect] Error 2
>> The platform is an IBM Power4 running AIX 5.3.  Compilers are IBM xlc
>> version 9.0 and xlf version 11.1.  Any suggestions would be appreciated.
>> Thanks,
>> Robert Yelle
