[mpich-discuss] building 64-bit MPICH2 on AIX
    Rajeev Thakur
    thakur at mcs.anl.gov
    Tue Feb  3 16:16:41 CST 2009
Can you send us the entire output of configure and make? You can send it to
mpich2-maint at mcs.anl.gov.
Rajeev
> -----Original Message-----
> From: mpich-discuss-bounces at mcs.anl.gov
> [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Robert Yelle
> Sent: Tuesday, February 03, 2009 2:56 PM
> To: mpich-discuss at mcs.anl.gov
> Subject: [mpich-discuss] building 64-bit MPICH2 on AIX
> Hello,
> Has anybody tried to build 64-bit versions of MPICH2 on an AIX
> platform?  What arguments should one use?  I tried to build a 64-bit
> version of MPICH2 (version 1.0.8) using the following arguments:
>  > ./configure
> --prefix=/usr/local/packages/mpich2/1.0.8_ibm-9.0-11.1_64
> OBJECT_MODE=64 C
> C=/usr/vacpp/bin/xlc CXX=/usr/vacpp/bin/xlc++ FC=/bin/xlf
> F77=/bin/xlf
> F90=/bin/xlf90 CFLA
> GS=-q64 FFLAGS=-q64 F90FLAGS=-q64 MPICH2LIB_CFLAGS=-q64
> MPICH2LIB_FFLAGS=-q64 MPICH2LIB_CX
> XFLAGS=-q64 MPICH2LIB_F90FLAGS=-q64
> Configure works fine, but "make" exits with the following error:
> make[3]: Leaving directory
> `/mnt/netapp/packages/src/mpich2-1.0.8/src/binding/cxx'
> make[2]: Leaving directory
> `/mnt/netapp/packages/src/mpich2-1.0.8/src/binding'
> make[2]: Entering directory
> `/mnt/netapp/packages/src/mpich2-1.0.8/src/env'
> /usr/vacpp/bin/xlc -DHAVE_CONFIG_H -I. -I. -I../include -q64 -O2 -q64
> -I/usr/local/packages/src/mpich2-1.0.8/src/mpid/ch3/include
> -I/usr/local/packages/src/mpich2-1.0.8/src/mpid/common/datatype
> -I/usr/local/packages/src/mpich2-1.0.8/src/mpid/common/locks
> -I/usr/local/packages/src/mpich2-1.0.8/src/mpid/ch3/channels/s
> ock/include
> ock/include
> -I/usr/local/packages/src/mpich2-1.0.8/src/mpid/common/sock
> -I/usr/local/packages/src/mpich2-1.0.8/src/mpid/common/sock/poll
> -I/usr/local/packages/src/mpich2-1.0.8/src/mpid/common/sock/poll -c
> mpich2version.c
> /usr/vacpp/bin/xlc -q64 -O2 -q64  -o mpich2version mpich2version.o  \
> ../../lib/libmpich.a -lpthread
> ld: 0711-204 SEVERE ERROR: Archive file ../../lib/libmpich.a
> cannot be
> processed.
>         The number of archive members (0), specified in the
> archive member
>         table, is less than or equal to 0 or is not
> consistent with the
> length
>         of the member table.
> make[2]: *** [mpich2version] Error 12
> make[1]: *** [all-redirect] Error 2
> make[1]: Leaving directory `/mnt/netapp/packages/src/mpich2-1.0.8/src'
> make: *** [all-redirect] Error 2
> The platform is an IBM Power4 running AIX 5.3.  Compilers are IBM xlc
> version 9.0 and xlf version 11.1.  Any suggestions would be
> appreciated.
> Thanks,
> Robert Yelle
