[mpich-discuss] MPI and threaded communication
Pavan Balaji
balaji at mcs.anl.gov
Tue Feb 3 05:02:31 CST 2009
Joey,
The problem you are trying to solve is identical to what another
application developer (for mpiBLAST) was attempting some time ago. The
solution used was something like this:
Thread 1:
while (1) {
MPI_Recv(ANY_SOURCE, ANY_TAG);
if (TAG == SPECIAL_TAG) /* This is a cancel message */
quit();
else
enqueue_msg();
Thread 2:
MPI_Irecv(SPECIAL_TAG);
while (1) {
dequeue_msg();
MPI_Isend();
MPI_Waitall();
if (tag == SPECIAL_TAG)
quit();
Thread 3:
/* When it wants to kill the two threads */
for i = 0 to 1 {
MPI_Send(SELF, SPECIAL_TAG);
/* Each thread will receive one of these two messages */
There might be small errors in the logic (it's 5am here, and I've run
out of coffee!), but the general idea should be there.
-- Pavan
Joseph Gonzalez wrote, On 02/03/2009 04:22 AM:
> Hi Again,
> Thanks for addressing my earlier question concerning thread and
> MPICH2. As part of our multithreaded system we are creating a
> callback based communicator with buffered send and receive queues.
> This seems like an obvious goal however I am having trouble
> terminating pending receives at the end of execution.
> All in the same MPI Process (pseudo-code) :
> Thread 1
> while(alive) {
> msg <- MPI_Recv(Any_Origin, Any_type)
> enqueue msg to handlers
> Thread 2
> while(alive) {
> msg <- dequeue outbound message
> MPI_Send(msg, msg.dest, msg.type)
> At some point an additional thread sets alive to false and would like
> to force the blocking Send and Recv to return (maybe with an error).
> How can I terminate the blocking sends and receives? I tried using
> MPI_ISend and MPI_IRecv followed with a MPI_Wait and again neither
> awake from the MPI_Wait when MPI_Cancel is invoked. From the
> specification it is clear how MPI_Cancel behaves before MPI_Wait is
> invoked but not after. We are introducing this abstraction because
> our algorithm will dynamically determine which nodes it needs to
> communicate with at runtime and it will be difficult to directly
> interleave algorithm and communication events.
> Thank you,
> Joey
> On Sun, Feb 1, 2009 at 6:15 PM, Joseph Gonzalez <jegonzal at cs.cmu.edu> wrote:
>> Hi,
>> We are building a threaded, event driven C++ wrapper for MPICH2. We would
>> like to be able to simultaneously send and receive messages from multiple
>> threads in the same process. If two threads simultaneous try to send to two
>> different rank destinations (on some remote machine) will they both transmit
>> simultaneously or is their an internal mutex that will prohibit this from
>> happening?
>> Thanks,
>> Joey
Pavan Balaji
http://www.mcs.anl.gov/~balaji
