[mpich-discuss] Fatal error in MPI_Barrier
    Antonio José Gallardo Díaz
    ajcampa at hotmail.com
    Mon Feb  2 17:29:21 CST 2009
Only have two nodes.
Node 1--> name: master --> hostname: wireless
Node 2--> name: slave----> hostname: wireless2
For wake up the cluster i use the command "mpdboot".
For example, i can to see how is the two node's id. In my job, i use for example MPI_rank(...) and i receive the number of the nodes, however if i use a MPI_Send(...) or MPI_Receive(...), mi job exit of the application and show me a error.
If i use "mpiexec -l -n 2 hostname", i receive:
0 : wireless
1: wireless 2
I don't know that it is the answer for your question.
Thanks.
From: thakur at mcs.anl.govTo: mpich-discuss at mcs.anl.govDate: Mon, 2 Feb 2009 15:52:52 -0600Subject: Re: [mpich-discuss] Fatal error in MPI_Barrier
The error message "unable to find the process group structure with id <>" is odd. How exactly did you configure MPICH2? Were you able to set up an MPD ring on the two nodes successfully?
Rajeev
From: mpich-discuss-bounces at mcs.anl.gov [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Antonio José Gallardo DíazSent: Monday, February 02, 2009 12:39 PMTo: mpich-discuss at mcs.anl.govSubject: Re: [mpich-discuss] Fatal error in MPI_Barrier
Hello. I Have tested to use the command:mpiexec -recvtimeout 30 -n 2 /home/mpi/mpich2-1.0.8/examples/cpi   and this is the result./********************************************************************************************************************************************************/                                                   Process 0 of 2 is on wireless        Process 1 of 2 is on wireless2        Fatal error in MPI_Bcast: Other MPI error, error stack:        MPI_Bcast(786)............................: MPI_Bcast(buf=0x7ffff732586c, count=1, MPI_INT, root=0, MPI_COMM_WORLD) failed            MPIR_Bcast(230)...........................:        MPIC_Send(39).............................:        MPIC_Wait(270)............................:        MPIDI_CH3i_Progress_wait(215).............: an error occurred while handling an event returned by MPIDU_Sock_Wait()                   MPIDI_CH3I_Progress_handle_sock_event(420):MPIDU_Socki_handle_read(637)..............: connection failure (set=0,sock=1,errno=104:Connection reset by peer)[cli_0]: aborting job:Fatal error in MPI_Bcast: Other MPI error, error stack:MPI_Bcast(786)............................: MPI_Bcast(buf=0x7ffff732586c, count=1, MPI_INT, root=0, MPI_COMM_WORLD) failedMPIR_Bcast(230)...........................:MPIC_Send(39).............................:MPIC_Wait(270)............................:MPIDI_CH3i_Progress_wait(215).............: an error occurred while handling an event returned by MPFatal error in MPI_Bcast: Other MPI error, error stack:MPI_Bcast(786)...............................: MPI_Bcast(buf=0xbf82bec8, count=1, MPI_INT, root=0, MPI_COMM_WORLD) failedMPIR_Bcast(198)..............................:MPIC_Recv(81)................................:MPIC_Wait(270)...............................:MPIDI_CH3i_Progress_wait(215)................: an error occurred while handling an event returned by MPIDU_Sock_Wait()MPIDI_CH3I_Progress_handle_sock_event(640)...:MPIDI_CH3_Sockconn_handle_connopen_event(887): unable to find the process group structure with id <>[cli_1]: aborting job:Fatal error in MPI_Bcast: Other MPI error, error stack:MPI_Bcast(786)...............................: MPI_Bcast(buf=0xbf82bec8, count=1, MPI_INT, root=0, MPI_COMM_WORLD) failedMPIR_Bcast(198)..............................:MPIC_Recv(81)................................:MPIC_Wait(270)...............................:MPIDI_CH3i_Progress_wait(215)................: an error occurred while handling an event rIDU_Sock_Wait()MPIDI_CH3I_Progress_handle_sock_event(420):MPIDU_Socki_handle_read(637)..............: connection failure (set=0,sock=1,errno=104:Connection reset by peer)eturned by MPIDU_Sock_Wait()MPIDI_CH3I_Progress_handle_sock_event(640)...:MPIDI_CH3_Sockconn_handle_connopen_event(887): unable to find the process group structure with id <>rank 1 in job 21  wireless_47695   caused collective abort of all ranks  exit status of rank 1: return code 1rank 0 in job 21  wireless_47695   caused collective abort of all ranks  exit status of rank 0: return code 1/********************************************************************************************************************************************************/The mpdcheck said that has a problem with the first ip but it's solved.I tested:mpdcheck -s                   and in the other node             mpdcheck -c "name" "number"    -------------->   Well.mpiexec -n 1 /bin/hostname ------------------------------------------------------------------------------------------------------------->   Well.mpiexec -l -n 4 /bin/hostname ---------------------------------------------------------------------------------------------------------->   Well.I have to say that with all command i have to put the options -recvtimeout 30 because but have problems. Without this option, say me:mpiexec_wireless (mpiexec 392): no msg recvd from mpd when expecting ack of requestWhat can i do?? Please help and sorry for my poor english.
From: ajcampa at hotmail.comTo: mpich-discuss at mcs.anl.govDate: Mon, 2 Feb 2009 18:17:39 +0100Subject: Re: [mpich-discuss] Fatal error in MPI_Barrier
Well, thanks for your answer.  Really, the name of mi pc is "Wireless" and the othes pc "Wireless2", i use in the two pc, the same user "mpi". I will try the mpdchech utility and then write something.Thank for all.Un saludo desde España.
From: thakur at mcs.anl.govTo: mpich-discuss at mcs.anl.govDate: Mon, 2 Feb 2009 10:55:03 -0600Subject: Re: [mpich-discuss] Fatal error in MPI_Barrier
Are you really trying to use the wireless network? Looks like that's what is getting used.
You can use the mpdcheck utility to diagnose network configuration problems. See Appendix A.2 of the installation guide.
Rajeev
From: mpich-discuss-bounces at mcs.anl.gov [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Antonio José Gallardo DíazSent: Monday, February 02, 2009 9:49 AMTo: mpich-discuss at mcs.anl.govSubject: [mpich-discuss] Fatal error in MPI_Barrier
Hello, this error show me when i try my jobs that use MPI.Fatal error in MPI_Barrier: Other MPI error, error stack:MPI_Barrier(406).............................: MPI_Barrier(MPI_COMM_WORLD) failedMPIR_Barrier(77).............................:MPIC_Sendrecv(123)...........................:MPIC_Wait(270)...............................:MPIDI_CH3i_Progress_wait(215)................: an error occurred while handling an event returned by MPIDU_Sock_Wait()MPIDI_CH3I_Progress_handle_sock_event(640)...:MPIDI_CH3_Sockconn_handle_connopen_event(887): unable to find the process group structure with id <��oz�>[cli_1]: aborting job:Fatal error in MPI_Barrier: Other MPI error, error stack:MPI_Barrier(406).............................: MPI_Barrier(MPI_COMM_WORLD) failedMPIR_Barrier(77).............................:MPIC_Sendrecv(123)...........................:MPIC_Wait(270)...............................:MPIDI_CH3i_Progress_wait(215)................: an error occurred while handling an event returned by MPIDU_Sock_Wait()MPIDI_CH3I_Progress_handle_sock_event(640)...:MPIDI_CH3_Sockconn_handle_connopen_event(887): unable to find the process group structure with id <��oz�>rank 1 in job 15  wireless_43226   caused collective abort of all ranks  exit status of rank 1: killed by signal 9I have two PC's with linux (kubuntu 8.10). I make a cluster using this machines. When use for example the command "mpiexec -l -n 2 hostname" i can see that it's all right, but when i try to send o receive some thing i have the same error. I don't know why. Please i need one hand. Thanks for all.
El doble de diversión: Con Windows Live Messenger comparte fotos mientras hablas.
Con el nuevo Windows Live lo tendrás todo al alcance de tu mano
_________________________________________________________________
Anímate y disfruta con los mejores juegos de Messenger, ¡descúbrelos!
http://www.vivelive.com/juegos/
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20090203/54911f1d/attachment.htm>
