[mpich-discuss] Problem building MPICH2 with shared lib on Mac OS 10.5.5
Blanchette, Marco
MAB at stowers.org
Sun Feb 1 16:28:41 CST 2009
Dear MPICH2 users,
I have been trying to build MPICH2 1.0.8 under Mac OS 10.5.5 with shared libraries. The shared libraries are required to build the R module Rmpi that allows us to run R in parallel across our cluster. However, I have been having a lot of trouble to get the Rmpi package built correctly and I am trying to investigate whether the problem boils down something going wrong while building MPICH2.
I have gcc installed as well as gfortran. I gave up for the moment to try building a 64-bit MPICH2 as the make process was breaking down at multiple places.
Right now I have been trying to get a 32-bit mpich2 deployed on my workstation and try to build Rmpi in 32-bit (a 64-bit will be require later...).
When I build MPICH2 following configuration with './configure --enable-sharedlibs=gcc-osx', MPICH2 build correctly and seems to run fine. However, I get the following error during the build process:
ad_fstype.c: In function 'ADIO_FileSysType_fncall':
ad_fstype.c:383: warning: comparison is always false due to limited range of data type
ranlib: file: ../../../lib/libmpich.a(osserv.o) has no symbols
ranlib: file: ../../../lib/libmpich.la(osserv.lo) has no symbols
ranlib: file: libmpichf90.a(mpi_base.o) has no symbols
Then, if I try to build the R package, I get an error related to the inability of the package to load the shared library.
Building MPICH2 without shared libraries following the default ./configure setting give the following errors
Are these bugs that prevent me from building the R module on the shared library or simple warnings that can be ignore?
Also, is there anyone that has successfully build a 64-bit MPICH2 with fortran support under Mac OS 10.5.5? Would you mind sharing your successful configuration setup?
Thanks for your help.
Marco Blanchette, Ph.D.
Assistant Investigator
Stowers Institute for Medical Research
1000 East 50th St.
Kansas City, MO 64110
Tel: 816-926-4071
Cell: 816-726-8419
Fax: 816-926-2018
