[mpich-discuss] one more error while running
    Pavan Balaji
    balaji at mcs.anl.gov
    Sat Dec  5 13:37:23 CST 2009
Did you follow the previous suggestions? Are you using mpd or hydra? Do
you have mpich2 installed on all the nodes and is the executable
available on all the nodes?
 -- Pavan
On 12/05/2009 01:31 PM, Anuj Patel wrote:
> it also gives sometimes error like this
> problem with execution of ./a.out  on  pratik.agrawal:  [Errno 8] Exec
> format error
> format error
> the pratik.agrawal is second node of cluster... we hae simple 2 node
> cluster right now..
> indyaah.destiny is the first node from where i am trying to run the code.
> any help..??
> On Sun, Dec 6, 2009 at 12:51 AM, Anuj Patel <indyaah at gmail.com
> <mailto:indyaah at gmail.com>> wrote:
>     Any idea about this error???
>     [root at indyaah runs]# mpiexec -n 4 ./mm8
>     Assertion failed in file ch3_progress.c at line 489: pkt->type >= 0
>     && pkt->type < MPIDI_NEM_PKT_END
>     internal ABORT - process 1
>     rank 1 in job 8  indyaah.destiny_37866   caused collective abort of
>     all ranks
>       exit status of rank 1: killed by signal 9
>     Anuj Patel
> mpich-discuss mailing list
> mpich-discuss at mcs.anl.gov
Pavan Balaji
http://www.mcs.anl.gov/~balaji
