[mpich-discuss] running job using ipoib through mpirun_rsh
    Dhabaleswar Panda
    panda at cse.ohio-state.edu
    Tue Dec  1 10:49:57 CST 2009
Using mpirun_rsh for IPoIB interface is not supported currently. The
TCP/IP interface supported in MVAPICH2 package is the same as MPICH2.
Thus, you need to use the job launching mechanism, as supported by MPICH2,
for running applications using IPoIB interface.  You can use mpirun_rsh
for all other interfaces (Gen2-IB, iWARP, PSM, RDMAoE, etc.).
Hope this helps.
DK
On Tue, 1 Dec 2009 chan at mcs.anl.gov wrote:
> Since this is a MVAPICH question, cc'ed this to mvapich-discuss.
> A.Chan
> ----- "Devesh Sharma" <devesh28 at gmail.com> wrote:
> > Hello list,
> > I am trying to run a job over a large cluster over IPoIB interface
> > but
> > it is failing.
> > How can I start the job using mpirun_rsh? does the hostfile specified
> > via -hostfile have format similar to what is used in MVAPICH2 while
> > running jobs
> > using ssm ADI over IPoIB?
> > -regards
> > Devesh
> > _______________________________________________
> > mpich-discuss mailing list
> > mpich-discuss at mcs.anl.gov
> > https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
