[mpich-discuss] Hydra issues
Pavan Balaji
balaji at mcs.anl.gov
Fri Aug 28 16:22:54 CDT 2009
Yup, you are right. I can reproduce the problem when I use more than one
node. I'll look into this next week.
-- Pavan
On 08/28/2009 02:46 PM, Scott Atchley wrote:
> On Aug 28, 2009, at 2:53 PM, Scott Atchley wrote:
>> I tried your test app again and it starts immediately without NO_MPI
>> set and is delayed when NO-MPI=1; the exact opposite of the above. I
>> tested IMB 2.3 and it too is delayed.
> I modified your test app (see below). I eliminated the sleep() and
> replaced it with busy work. I print it out at the end to avoid the
> compiler removing the code (my gcc did).
> If I run it with -n 4 over two nodes, I see the output from the local
> host in real time (and interleaved). The other two ranks' output does
> not appear until the end of the run and the output is serialized.
> Scott
> #include <stdio.h>
> #include <stdlib.h>
> #include "mpi.h"
> int main(int argc, char *argv[])
> int i, use_mpi = 0, rank = -1;
> long sum = 0L;
> use_mpi = (!(getenv("NO_MPI"))) ? 1 : 0;
> if (use_mpi) {
> MPI_Init(&argc, &argv);
> MPI_Comm_rank(MPI_COMM_WORLD, &rank);
> for (i = 0; i < 20; i++) {
> int j;
> if (use_mpi)
> MPI_Barrier(MPI_COMM_WORLD);
> printf("%d: Hello World!\n", rank);
> for (j = 0; j < 10000000; j++) {
> sum += j;
> if (j > 0) sum /= j;
> if (use_mpi) {
> MPI_Finalize();
> printf("%ld\n", sum);
> return 0;
Pavan Balaji
http://www.mcs.anl.gov/~balaji
